You've been doing it wrong. Seafoam injection port
Old Feb 19, 2011 | 05:46 PM
KU_MechE's Avatar
So, i'd like to clarify, the improper way to run Seafoam through the car's intake system is to use a vacuum line that only feeds one cylinder. If you used the brake booster vacuum line, you've only been feeding a single cylinder.
In this picture below, you can see the brake booster vacuum line directly feeds a single runner (either Cyl 3 or 4). This means your Seafoam is not at all distributed to any other cylinder.
In this picture below, you can see the PCV vacuum port feeds the plenum before it divides into the 6 runners. While you'll never get perfectly even distribution, hopefully some of your Seafoam gets to each runner.
Old Feb 19, 2011 | 05:52 PM
DeathCougar's Avatar
I never even thought of that before....
Good call!
Old Feb 19, 2011 | 06:38 PM
corax's Avatar
Good point. On newer vehicles with an electric PSV (evap Purge Control Solenoid), use that hose - it should be sited from the factory for optimal distribution of evaporative emissions (fuel vapors). In general, try to get as close behind the throttle body as possible.
Old Feb 19, 2011 | 06:45 PM
87hillbillyoter's Avatar
wow i had quite a few people tell me not to run through the pcv and through the brake booster. i did get way more smoke through the brake booster thats for sure
edit: im an idiot. didnt see the forum this was in
Old Feb 19, 2011 | 09:59 PM
BajaRunner's Avatar
Hehe no offense....!!! But... ??
I think its been pretty clear that the 3.4l seafoam treatment is through the PCV hose for at least the last 7 years I have been a member here!
Old Feb 19, 2011 | 11:12 PM
KU_MechE's Avatar
I hope that's the case for everyone. These posts lead me to believe otherwise:
https://www.yotatech.com/forums/f2/s...65/#post637781
https://www.yotatech.com/forums/f2/s.../#post50598716
https://www.yotatech.com/forums/f2/s.../#post50736894
Old Feb 20, 2011 | 09:49 AM
mt_goat's Avatar
Good point, personally I recommend putting it in the gas tank.
Old Feb 20, 2011 | 10:04 AM
vital22re's Avatar
totally a bro
not everyone chooses to search and not everyone has common sense to see its only hitting one maybe 2 cylinders from the booster. But yes the pcv is usually the best place on all motors.. usually...
Old Feb 20, 2011 | 10:10 AM
BajaRunner's Avatar
Wow! I can't believe it. Always seemed obvious to me. Doesn't the can say to put it in the PCV hose?
Anyways, interesting. Glad you posted this. I am sure its going to help a lot of people.
Old Feb 20, 2011 | 05:25 PM
Gerdo's Avatar
Good post.
Let me ask a question. Adding it to the gas can help clean injectors and the complete gas system. And sucking it into the engine is a much higher volume of seafoam and tends to clean the valves and cylinders better. Remember that sucking it in won't clean the injectors.
I guess that wasn't really a question but more of a statement.
Old Feb 20, 2011 | 06:40 PM
BajaRunner's Avatar
Guys ever notice when you put it in your gas tank your exhaust is white?
Old Feb 20, 2011 | 10:37 PM
^ not for me, only when i did it in the intake
Old Feb 22, 2011 | 06:20 PM
Gerdo's Avatar
My guess would be, No. This would be because the seafoam is diluted heavily by the gas.
When it's used in the gas it's mission is to clean the fuel system including the injectors.
When used by sucking it into the engine by a vacuum line it's mission is to breakdown and remove the carbon buildup. The high concentration of seafoam and the carbon being burned cause the smoke.
Old Feb 23, 2011 | 06:15 PM
89old blue's Avatar
so what color smoke are you guys seeing by pulling seafoam through the intake? white?
Old Feb 24, 2011 | 07:27 PM
Red3.slow's Avatar
Yes white seems to be the norm at least in all my applications.
Old Feb 24, 2011 | 07:46 PM
89old blue's Avatar
Ok so it is true that it doesn't actually work and the white smoke is the just the seafoam itself buring? I've never seen carbon burn white. Just curious what kind of difference or affect you guys have seen doing this?
Old Feb 24, 2011 | 08:04 PM
James Woods's Avatar
I personally did a service on a car with about 140,000 miles on it and one part of the service is the sea foam clean through the intake while I was waiting on an upsell headgasket job on the same car, afterwards they called and said do the headgaskets and when I took the heads off, those combustion chambers were nice and carbon free, I swear by it since then.
Old Feb 24, 2011 | 08:05 PM
definitely works. i didnt pass smog one day, did seafoam(with a few other things) passed the next day.
Old Feb 24, 2011 | 08:35 PM
Bako88's Avatar
What did the combustion chambers look like before the Seafoam?
Old Feb 24, 2011 | 09:20 PM
Usually a Subaru with over 100,000 miles I spend about an hour scraping and cleaning carbon from both heads. This car just about 10-15 min. No I do not have a before and after comparison on the chambers of the same car, but a car that came in 20,000 miles overdue for spark plugs and 5000 miles over on his oil change, he obviously didnt take care of it, and from the thousands of headgasket jobs I have done, this was the cleanest next to the 1700 mile mishap from another dealership.
