YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 02-04-2008, 09:42 AM   #1 (permalink)
mkgarrison5's Avatar
yota pink or yota red coolant
hey guys, just talked with my local dealership and mentioned that i wanted pink instead of red (bc they use tap water mix with the red and i dont want tap water) he told me that i cannot use the pink (btw i drive an 02 v6 4x4 taco) bc the system was not designed for it.. is there any truth to this?? he told me red only.
__________________
02 Tacoma 4-Dr 4x4 V6
117k miles
mkgarrison5 is offline
Sponsored Links
To remove this ad, register today!
Old 02-04-2008, 10:18 AM   #2 (permalink)
86tuning's Avatar
You can use whatever you want.
The 02 vehicles came out before the super-longlife coolant was introduced in 04.
If you substitute SLLC (pink) in place of LLC (red) don't expect 5 years out of it, you'll have to change it in a couple years anyways due to mixing of the new/old coolant.
Toyota says, 5 years for initial, then 2 year intervals afterwards.
Me, I'd use regular red LLC (red) and filtered or distilled water and be done with it. LLC chemistry isn't as aggressive as SLLC and therefore is nicer to your skin, etc.
Generally, tap water is a no-no, but filtered water is fine.
__________________
- Brian
86tuning is offline
Old 02-04-2008, 10:19 AM   #3 (permalink)
jjrgr21's Avatar
the only difference between the pink and red, the pink is already cut to 50/50 and cost's the same. around $22 a gallon.
my 03 takes pink/red and my 98 took el-cheapo green.
__________________
2003 4WD TRD Tacoma
1986 4Runner
jjrgr21 is offline
Old 02-04-2008, 10:31 AM   #4 (permalink)
dirtoyboy's Avatar
I have never heard of PINK coolant...just red, green and orange
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler.
I'm the yota junk man......PM me for ALL your parts needs NEW or USED
Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall!
It's a Jaap thing....You wouldnt understand
Quote:
Originally Posted by SwampThing View Post
Oh, after a consult with Mr. Anheuser, I think I beer-stormed a way to test the gears
dirtoyboy is offline
Old 02-04-2008, 10:49 AM   #5 (permalink)
wrong the pink is the extended life version and is mixed 50/50 and yes it is different than red in more ways than one. but is it harmful to my taco??
also my local dealerships (all 3 of them) use tap water and have been since they have been open (15+ years) and they swear that tap water is ok with yota red coolant as long as you flush / change every 30kmiles..
i am having them change my tbelt, waterpump and thermstat changed thats why i asked them.
__________________
117k miles
Old 02-04-2008, 10:54 AM   #6 (permalink)
fast7mtoys's Avatar
never had a problem with tap water, NEVER!
fast7mtoys is offline
Old 02-04-2008, 10:58 AM   #7 (permalink)
CJM
CJM's Avatar
Like I said in another post, my shop uses tap water and no issues.
__________________
96' T100 SR5 4x4, ISR mod, Custom ABS snorkel, KC 57's Hella optilux el cheapo backup lights. Cobra 19III CB, Firestick 4ft antenna, Bilstein shocks.
Be polite. Be professional. But, have a plan to kill everyone you meet.
CJM is offline
Old 02-04-2008, 11:04 AM   #8 (permalink)
dirtoyboy's Avatar
yup. you're right......learn me sumfin new everyday...
what I was reading says the pink is "aluminum engine" friendly and is silicate free....is it really good for 100k?
__________________
Old 02-04-2008, 11:08 AM   #9 (permalink)
no probably not. i would half that to be honest. nothing really goes as far as they say it goes OEM wise imo.. it really depends on how you drive your vehicle. the rougher you are (city, 4x4, ect ect) the more often you should change fluids, grease and oil.
__________________
117k miles
Old 02-04-2008, 11:09 AM   #10 (permalink)
MTL_4runner's Avatar
Send a message via AIM to MTL_4runner
Nope, he's full of it. Running pink instead of red will not damage your engine in any way.
The two coolants are very similar except that the pink has added OAT technology.
Ask him why, I'd be curious what sort of reasoning he comes up with besides "that's what called out in the computer".
__________________
- Jamie
1996 4Runner SR5 4X4 Auto
Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift
Best OBD II scan tool I have used!.
.....and I am AMERICAN!
MTL_4runner is offline
Old 02-04-2008, 11:12 AM   #11 (permalink)
Quote:
Originally Posted by MTL_4runner View Post
Nope, he's full of it. Running pink instead of red will not damage your engine.
i agree with you and i did ask. he said that the pink is harsher for the pre 2004 vehicles and that when toyota switched to pink they changed a few things in the coolant system in order to use the pink... my side question is would the OAT be the "issue" that he talks about??
__________________
117k miles
Old 02-04-2008, 04:13 PM   #12 (permalink)
OAT = Organic Acid Technology
Yes, I'm sure that's what he was talking about and that is what gives the coolant it's "super long life".
Here's some good reading on the subject of coolants:
http://www.ultimateyota.com/index.ph...26&topic=328.0
What exactly is he claiming they "switched out"?
__________________
- Jamie
Old 02-04-2008, 04:31 PM   #13 (permalink)
surf4runner's Avatar
... pink is the extended life version ... but is it harmful to my taco??
pink is the right color for tacos
__________________
sarcasm noted...and appreciated
im with the banned
Quote:
Originally Posted by fustercluck View Post
I was traumatized. I had nightmares of trained attack tupperware beef-logs chasing me all night! Don't bend over, Fuster!!!!!
Quote:
Originally Posted by Lysmachia View Post
Just pile us nekkid in an engine bay and drizzle us with gear oil and watch the fun!
surf4runner is offline
Old 02-04-2008, 11:45 PM   #14 (permalink)
stormin94's Avatar
I'd go for yota-PRESTONE in the yellow jug.
__________________
1994 Toyota 4Runner SR5 4X4
208,000 miles and counting
3.0 V6, 5 speed
14/19 MPG city/hwy(before 33's)
Current Mods
Headers, 2.5" Flowmaster custom exhaust, K&N FIPK
KC Daylighter 100 Watt lights
Ranchos x4, 2" Lift Downey coils
33-12.50 M/T's, 1" t-bar lift, 1" body lift
Tow pkg w/ lighthookups
Silverstar Headlights, Pioneer Deck w/XM
Brushguard
250Watt JLAudio 8" W3 Sub
Future Mods
12V Aux outlet-400/800peak inverter
roof basket/lights
Air locker
4.88 gears
H.O. Alternator
stormin94 is offline
Old 02-05-2008, 02:04 AM   #15 (permalink)
Demon's Avatar
wow!!! i had no idea tap water was bad...do this mean only on new cars or any in general??? cus i bought the green presto or whatever u call it, and i mixt it with tap water...
Demon is offline
Old 02-05-2008, 02:08 AM   #16 (permalink)
Justinvd's Avatar
We use tap water also at our shop
Justinvd is offline
Old 02-05-2008, 05:52 AM   #17 (permalink)
well i am not going to take my chances with tap water. i will buy 2-4 gallons of distilled water and have them mix that water with the yota red. i am going to have them write it down on the service sheet to make sure they do that and stress it. they seem pretty reasonable as far as what i want done to it and how i want it done so ill cross my fingers..
-- btw i do have prestone "any make, any color" in there now. it has only been in there about 20k miles or so. time to get rid of it.
__________________
117k miles
Old 02-05-2008, 07:23 AM   #18 (permalink)
Seems like alot of trouble for nothing.
I'd just fill it with the long-life pink and forget about it.
__________________
- Jamie
Old 02-05-2008, 07:26 AM   #19 (permalink)
i called the guy again and he changed his mind and said this "i guess it would be ok to use the pink BUT we have to make sure all of the red is out of your truck first"... i mean come on man.
i am going with the pink and just tell them to drain what they can out of the coolant system. this is rediculus.. i would rather have the pink anyway and change it every 3-4 years
__________________
117k miles
