Wrong Order from Summit
Old May 10, 2005 | 05:21 PM
hill's Avatar
Unhappy Wrong Order from Summit
So i ordered up a steering stabilizer bar and what i thought was the sway bar bushing kit....
what i got...a steering shock for a different truck..the mounting points are totally different then my truck...(see pics).....or am i missing something
and control arm bushings....all i wanted was sway bar bushings.
FRICK!!
Attached Thumbnails Wrong Order from Summit-100_0524-wince-.jpg   Wrong Order from Summit-100_0525-wince-.jpg   Wrong Order from Summit-100_0527-wince-.jpg
Old May 10, 2005 | 06:55 PM
leebee's Avatar
4crawler.com
lee
Old May 10, 2005 | 07:03 PM
hill's Avatar
4crawler doesnt have the end link kit for sway bars...which is what im looking for
Old May 10, 2005 | 07:22 PM
green91runner's Avatar
4crawler sells disco's with polyurethane busings, but no, they dont carry the bushings for the actual swaybar.
Old May 10, 2005 | 07:27 PM
hill's Avatar
Im just going to return all this summit stuff and look elsewhere.
Old May 10, 2005 | 07:34 PM
jimbo74's Avatar
sounds liek a miscommunication, i have ordered stuff from summit no problem... is it possible that you misrepresented what you wanted? my stock steering stabilizer looks like the new one you got....
Old May 11, 2005 | 05:55 AM
DaveInDenver's Avatar
Probably you're not missing anything. Universal steering dampers sometimes look like that and you are expected to use adapters or sometimes brackets that clamp on your tie rod instead of the original mounting location. I would buy an Old Man Emu SD33, this is a direct fit upgraded damper for your truck.
As far as sway bar bushings, how about Energy Suspension? I've seen them at the 4x4 shops and Pep Boys. They have a website:
http://www.energysuspension.com
I've ordered stuff from Summit as well. They're usually good about getting the parts right, although sometimes they forget to tell you it's backordered for 2 months or some other important detail. But typically (particularly if you have the manufacturer's p/n) they get it right. Energy Suspension has an online catalog that you can get the correct p/n and then you should be good.
Old May 11, 2005 | 06:07 AM
MTL_4runner's Avatar
I would just return the stuff to Summit (I've had only good experiences with them too) and order from these guys (they are a supplier for energy suspension products): http://www.suspension.com/toyotapickups.htm
Old May 11, 2005 | 06:09 AM
shiftless89's Avatar
give barb or chris a ring at www.trdparts4u.com the best price you will find on ome stuff.. I just put an ome stabilizer on my truck, good stuff. tell em your from yotatech
Old May 11, 2005 | 06:38 AM
4Crawler's Avatar
I do have a supply of poly end link bushings. If you need a set and can't find them elsewhere, I can get them to you. With the 2nd gen 4Runner, you likely only need bushings of one end of each end link.
Old May 11, 2005 | 07:01 AM
hill's Avatar
4Crawler...that would be fantastic...
Old May 11, 2005 | 07:29 AM
4Crawler's Avatar
This would be the end link bushing kit:
4 bushing halves would do one end of each end link, for a double-ended end link, 8 bushing halves would be required. Bushings are 1" OD and 3/8" / 10mm ID.
Old May 11, 2005 | 09:01 AM
hill's Avatar
4Crawler.... id like to do the front and back... i think my links are single ended.
Do you have the bushings that connect from the sway bar to the frame?
Cost? Shipping to Calgary Alberta T3B 5X1
Thanks again.
Old May 11, 2005 | 09:08 AM
4Crawler's Avatar
I would need the dia. of the sway bar to get the right bushings for that. The end links are $20 for the full set (8 bushings halves) or $10 for the 1/2 set. Shipping would be $4.50 via Global Priority Mail (4-10 days) or I can get other shipping options (faster and less expensive options).
Old May 11, 2005 | 10:27 AM
mt_goat's Avatar
FRICK!!
Steering stabilizers, just like shocks, have two main types of ends for mounting, loop ends and post ends. My truck takes a steering stabilizer that has two loop ends, and it looks like from your pics yours does too. They sent you one with two post ends, no easy way to make that work.
JNapolitano
Nov 14, 2019 07:46 PM
djohnson13
Sep 4, 2015 12:35 PM
PureTacoma_Tundra
PureTacoma_Tundra
Jul 23, 2015 11:20 AM
smiley52
Jul 11, 2015 05:16 AM
