Wiring guru's: Why do I keep blowing my 10A AC fuse?
Old 11-03-2003, 10:13 AM
rimpainter.com's Avatar
I have my Flex-a-lite fans hooked up to the AC clutch wire. When the clutch engages, the fans go on to cool the condensor while sitting. I am trying to install a manual override switch that allows me to turn off the fans when the AC clutch engages. There is no need to have the fans running while on the freeway IMO. I have noticed a .5 MPG decrease with the fans running on the freeway.
I tapped into the flex-a-lite AC wiring that goes to the FLX control box from the AC clutch. I fire up the truck, kick on the AC...everything is cool. The switch is even illuminated at this point. The problems start when I turn the switch off. I immediately blow the Toyota 10A fuse under the hood. Every time, it never fails.
So do I need a relay in order to branch off the clutch engagement wire? Why does this keep happening?
Please help.
PS: I do not want to run a switch that disables the fans completely. I still want to enjoy the safegaurd of the thermoswitch.
RyanJ989
11
04-07-2021 09:41 AM
Scotttekoch
09-28-2015 10:30 PM
punks_is_4x4
09-19-2015 05:52 AM
Ricu_air
09-19-2015 05:35 AM
Gone Fission
09-04-2015 12:18 PM
Quick Reply: Wiring guru's: Why do I keep blowing my 10A AC fuse?
