Will these fit my truck?
Will these tires and rims fit without or with MINIMAL rubbing? My 99 has a 3inch lift. thanks
http://cgi.ebay.com/ebaymotors/ws/eB...m=160122464946
they will probably fit. BUT those tires dont look very new and those rims like roorrunner said probably look like garbage in person.
I think a new set of BFG AT's can be had for around $600 new from tire rack
i have 3.5" fabtech adjustable coilovers and i am running 33" by 12.50" mud terrains and i have clearance . but a quick question ? has anyone had problems with there p/s pump cause i am on number three , refurbished from carquest , and any help will be much appreciated ,
is this a 99 4runner or tacoma?
My tacoma has 15" wheels on it..it also came with 225's on stock
im pretty sure all 4wd runners came with 16" wheels and have larger calipers than the tacomas since they weigh a few hundred pounds more
nah dude just looking...
How bout this set up If i got BFG 33x12.50x15 with these rims http://www.wheelersoffroad.com/tacomawheels.htm (the 15 with type B backspacing) will that fit or should i just get a 32x11.50? thanks guys
either should fit on those rims. and yeah, those are really run-of-the-mill wheels, but for good reason. very simple design so it can't NOT look good, and its cheap. hell of a lot better than those on ebay
Those look like American Racing Outlaw II's, which I had in 15x8 on my tacoma and really liked. They definately dont look good in 15x10 in that pic though, might just be the white letters on the tires or something
yep, same bolt pattern. I heard the hub rings were SLIGHTLY bigger on newer trucks that may not center exactly right and cause some vibration, but I have a buddy with 01+ TRD Tacoma/Tundra wheels on his 88 truck and they are fine.
awesome thanks. now i will dig them out of the garage and slap them on the 4runner. and if i am lucky, it will pass recon, then safety, then i can get it off this damned island to one that doesn't suck
Thanks RooRRunner, Will those tires fit in my wheel well? without rubbing? thanks. remember i have a 3 inch lift, thanks alot
greenmachine93
06-25-2015 07:50 PM
nrgetic99
07-23-2002 04:42 AM
AUJWE
7
07-11-2002 09:46 AM
