Who's running Camry cams in their 3.4?
Hey guys, I'm picking up a set of Camry cams today to swap into my Tacoma, who is running them, and how did you shim for the new cams? Much appreciated to all that can help.
~Tuck
~Tuck
The cams are from the 3vz camry. This has been theorized for years but I have yet to see a documented case of someone actually doing it.
The idea is to give you a wider powerband without the massive power falling off up top, this should lead to a little more power in the higher RPM's as well with minor if any losses down low.
Overall it is an interesting idea although a lot of work for minor gains if you ask me unless you are inside the motor anyways. I would boost it first then worry about cams, that is when they would do the most good anyways.
I like the post below, from the following thread. 3VZ-FE camry cams in a 5VZ-FE 3.4L!
Pretty well clears the issue up like a dark cloudy day I'd say!
Another one of the things the 3VZ-FE(or 2VZ-FE) has...that the 5VZ-FE doesn't...is ACIS(Acoustic Control Induction System) variable-length intake manifold technology.
http://www.mr2.com/files/mr2/techinf...Data/3vzfe.pdf
Ok, let me hold your hand for a second...
The 5VZ is distributorless... (EDIS)
The 3VZ has a distributor...
We're talking about putting 3VZ cams in a 5VZ motor...the 3VZ cams have a notch for the distributor to be driven by the end of the cam. The 5VZ has the casting in the heads for a distributor to be inserted but instead of having the hole for the distributor it is just solid aluminum. The head would have to be milled where the 'dizzy' would be inserted but then the 5VZ would, subsequently, have a distributor then...
And that is how I win...
Notice my wording in my previous post... "I will TRY to put a dizzy on a 5VZ using 3VZ parts"
AKA, the 5VZ doesn't yet have a distributor. But I will attempt to swap it over from the 3VZ...
Not sure the distributor argument is a nail int he coffin. The 3sgte also uses a distributor but you can remove it no problem as many do since the cam is still completely inside the head. The only difference is a notch on the end of the cam but that doesn't effect anything.
From the same thread...
ok time for me to get yelled at but I am kinda curious if anyone did find out if these cams will work....to the guy who wants to put a "dizzy" on a 5vz, you're retarded you will get nothing out of that. I just want to know if an after market 3vz cam will work in a 5vz and what the honest upside and down sides are. Any dynos on this?
It's more a matter of, is somoene willing to try this swap or not. Since, as far as anyone knows, they might be fully compatible/direct bolt-in. Frankly, I tend to think they would be(even based on the limited evidence available). And it might be worth the while...or not...who knows?
Here's some 3VZ-FE cams to look at.
I found this over on ToyotaNation:
3VZ-FE
Displacement: 2959cc
Intake camshaft duration: 230
Exhaust camshaft duration: 230
Valve overlap: 12 degrees
Intake valve lift: 7.85 mm
Exhaust valve lift: 7.60 mm
Intake valve diameter: 34.0 mm
Exhaust valve diameter: 27.3 mm
Intake valve overall length:
Exhaust valve overall length:
Valve stem diameter:
I couldn't find anything on the 5VZ cams.
3VZ-FE
XtraCab
04-12-2020 05:25 AM
WTB[PacNorWest]: WTB - Tacoma/4runner 3.4 Charcoal canister and igniter
94whiterunner
07-12-2015 07:15 PM
