Where is the ECU on a 2004 Tacoma?
Old 04-26-2005, 10:45 AM
mt_goat's Avatar
Anyone know where the ECU is on a 2004 Tacoma double cab 4x4? I need to know but I don't have one to check out. If it is like mine it would be behind the passinger side kick panel.
Old 04-26-2005, 12:48 PM
mt_goat's Avatar
Any guesses? Where was it on the 2004 4runners?
Old 04-26-2005, 01:03 PM
jc1kz's Avatar
on my 2002 4runner it is behind the glove box....
Old 04-26-2005, 01:19 PM
mt_goat's Avatar
Is it like bolted to the firewall behind the glovebox then?
Old 04-26-2005, 02:11 PM
midiwall's Avatar
If it's in the glovebox area, then it's above the box, you have to pull the box to get to it. (on mine) The box is held in with 3 10mm bolts and 2 Philips screws.
As you pull it, BE CAREFUL of the yellow connector - that's for the airbag.
Whatcha' lookin' to do? It's always interesting to hear that someone's looking for the ECU.
Old 04-26-2005, 04:29 PM
mt_goat's Avatar
What happens if I touch the air bag plug?
Old 04-26-2005, 04:37 PM
WATRD's Avatar
It causes an imbalance in the space/time continuum and you will wind up being your own grandfather.
Old 04-26-2005, 04:41 PM
mt_goat's Avatar
Oh good, I thought it might be something serious there for a minute.
Old 04-26-2005, 05:10 PM
Gangus2006's Avatar
your airbag will blow...not good when your face is 2" away from it...
disconnect the battery adn depress the brake pedal for 10 sec before doing this...
...wait, you should anyways if youre playing with teh ECU...
Old 04-26-2005, 06:26 PM
mt_goat's Avatar
Wow, really? If you disconnect the battery and press the brake pedal can you unplug the air bag then?
Old 04-26-2005, 10:00 PM
midiwall's Avatar
Disconnecting the battery will discharge the airbag firing circuit so it won't go off.
The brake pedal thing is something that has been mentioned in other threads. The thought nehind it is that there's some residual voltage left in the electrical system after the battery is disconnected, and activating the brake lights will drain that off.
Actually, there are a LOT of little circuits in a vehicle that will do that for you... the time keeper on a clock, the ECU, the keep-alive on the radio.
Disconnect the battery and you'll be fine.
Old 04-27-2005, 04:00 AM
mt_goat's Avatar
Thanks Mark.
Old 04-27-2005, 06:03 AM
EnolaGaia's Avatar
Originally Posted by midiwall
If it's in the glovebox area, then it's above the box, you have to pull the box to get to it. (on mine) The box is held in with 3 10mm bolts and 2 Philips screws. ...
That's the way it is for the ECM on the '04 Taco, too (behind the glove box).
According to the 2004 FSM diagrams, you remove (2) Phillips head screws to remove the glove compartment unit, (2) screws + (1) bolt to remove the Lower No. 2 finish panel, and (2) bolts to dismount the ECM.
Old 04-27-2005, 06:21 AM
mt_goat's Avatar
Hey thanks a lot. Do you know of any links to a 2004 truck FSM?
G-off
12-29-2015 12:44 PM
EatChipsNow
09-09-2015 01:25 AM
Highlander Giant
09-08-2015 06:46 PM
Tacoma1313
09-08-2015 01:27 PM
zz_denis
09-06-2015 03:43 PM
Quick Reply: Where is the ECU on a 2004 Tacoma?
