Where does the tachometer signal originate?
Old 08-21-2011, 08:09 AM
Winch's Avatar
Hi guys
I'm putting a diesel into the Tacoma using a mechanical injection pump from a 1KZ-T (Not TE). Does anyone perhaps know if there is a way to use the signal from the pick-up sensor on the pump to get the tach to work? The FSM for the Tacoma is confusing because in the diagram it seems to indicate that the signal comes from the Igniter, but in the description it says that the crank and camshaft position sensors are used. Thanks
http://www.ncttora.com/fsm/2003/Wiri...mci/013sis.pdf (Page 2)
http://www.ncttora.com/fsm/2003/Wiri...i/017ecs5v.pdf (No 1(4) on Page 5)
Old 07-11-2012, 09:13 AM
Winch's Avatar
Well just wanted to bring this up again to see if anyone knows.
Old 07-11-2012, 05:17 PM
hambob's Avatar
I had a 95 pickup and the tach wire came off the ignition coil. but looking at the wiring diagram,it looks like the signal comes from the ECM and goes to the combination meter control circuit.
Old 07-12-2012, 01:23 AM
totally a bro
Staff
vital22re's Avatar
rpm signal comes from the ignitor. Its usually a black wire. But if you're running a diesel... They have to pull from somewhere else I think as they don't use the same system.
Old 07-12-2012, 06:23 AM
snobdds's Avatar
I have seen people who swap in cummins 4bt's cut notches in there crankshaft then put in a ford explorer 2 wire camshaft position sensor to read RPM. I will try to find the thread on mud to show what there doing...Found it, see last page.
http://forum.ih8mud.com/hardcore-cor...thread-13.html
Shoua
13
05-22-2016 05:19 AM
O Holy P
08-18-2015 02:33 PM
Runner4Luke
08-12-2015 06:42 AM
Dennisx2
08-10-2015 06:48 AM
Dennisx2
08-04-2015 01:26 PM
Quick Reply: Where does the tachometer signal originate?
