Where can i put the tranny temp sender on a 2000 4runner v6??
Old 05-22-2007, 01:17 PM
Texas_Ace's Avatar
Question Where can i put the tranny temp sender on a 2000 4runner v6??
Ok i know i saw a thread about this not to long ago but i can't find it for anything!
Where can i put the tranny temp sender? Is there an adapter that i can get that will convet the tranny coolent lines to 1/8 ntp thread and back again so i can put a tee in there?
I have a 2000 4runner limited V6. and i can't put it in the stock sender spot as you can't take it out without taking half the tranny apart and even then you can't put a tee on it due to the space. So where and how do i do it???
I just installed a tranny cooloer and it is drained so i want to get this done QUICK. Thanks!
Old 05-28-2007, 09:20 PM
Crazychopstick's Avatar
You could order a sender block from ipt. I bought one when I did a tranny cooler on my Tundra. Or you could make your own from Home Depot supplies.
Old 05-28-2007, 09:47 PM
Texas_Ace's Avatar
That home depot is what i ended up doing as i was there anyways and i went to see if they might have some fittings that i could use. So i ended up with a big fitting that works quite well.
I was going to delete this thread but there is no option. Thanks for the help though!
ACZR
06-23-2015 07:55 PM
Schif
06-20-2015 08:39 PM
94 First Responder
06-06-2002 02:19 PM
jalaber
05-25-2002 04:04 AM
Quick Reply: Where can i put the tranny temp sender on a 2000 4runner v6??
