whats wrong? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-04-2003, 07:20 AM   #1 (permalink)
metal22lica's Avatar
Send a message via AIM to metal22lica
whats wrong?
ok guys... i was wondering if anyone knew what could be the cause of the problem. while i am slowing down (25 miles per hour and below) or taking off (20 miles per hour and below) i notice this rotation viberation (dont know any other way to put it) its really bad when i am slowing down. it makes the whole truck shake and it also makes like a deep waa waa waa noise ( hehe..sorry for the bad sounds with words) the tires (Michelin XCX/APT) are loud but im not sure if that would cause them to be. the steering wheel also shakes. could it just need the tires balanced and rotated? bad cv joints? any ideas guys? thanks a lot. sorry for using "slowing down" a lot but this is when i really notice it.
i have a 1990 4runner 4x4...just incase you didnt notice below...
__________________
SOLD??? Never
1990 Automatic V6 4WD SR5 4Runner
Mods: Downey 1.5 HDs, Aisin Hubs, CD, CB with a 4' Firestik, Husky Liners, Maglite Mod, 2nd Gen Airbox Mod, K&N filter and a Smittybilt Brush Guard with 4 lights.
Next: Rims? Shocks? Exhaust?
PICS
-Corey
metal22lica is offline
Old 02-04-2003, 07:30 AM   #2 (permalink)
rimpainter.com's Avatar
My guesses would be wheel bearing(s) or driveshaft.
rimpainter.com is offline
Old 02-04-2003, 08:33 AM   #3 (permalink)
Senior Member
Send a message via AIM to jacksonpt
I had a wheel bearing go on one of my back wheels and it made a sound similar to the one you are describing. However, it did not cause my rig to shake - I'm not sure if a front bearing would cause shaking, but I doubt it. Also, when my bearing went, it only whined above 30mph, the opposite of your symptom. If it wasn't for the fact that it only happens at low speeds, I'd guess that it was a ceased front caliper.
__________________
Jackson - My Site
96 SR5 4x4 - 33" MTs, open diffs, and 3.90s - LET'S ROCK!
My runner has bee traded in *sniff* on an 06 SR5 long bed d-cab Tacoma. The tacoma is nice, but... *sniff* ... I'll update my site when I'm done grieving.
jacksonpt is offline
Old 02-04-2003, 08:51 AM   #4 (permalink)
i just had my front wheel bearings repacked, and brakes done..so im guessing its not them. what would be wrong with the drive shaft? i just lubed it a month or so ago. it does not matter if i am braking or not..it still does it.
__________________
SOLD??? Never
PICS
-Corey
Old 02-04-2003, 09:00 AM   #5 (permalink)
Quote:
A worn or unbalanced drive shaft could cause the acceleration shaking. I had the exact same symptoms (accelerating only) on my 79 Supra, and it was the driveshaft balance.
It would lightly shake from 0-30 under hard acceleration.
I dont know about the deceleration part of the problem...
Old 02-04-2003, 10:08 AM   #6 (permalink)
Staff
UKMyers's Avatar
Send a message via AIM to UKMyers
A worn out U-Joint on the driveshaft will also cause the symptoms you described. Never heard one make a noise though.
__________________
2006 Tundra Double Cab TRD Offroad 4.7 IForce Bilstein 5100's, 285 BFG's, Panther Wheels, Limo Tint
1994 4-Runner SR5 5 Speed SASed, Detroits, Armored, Dual Cases, 37" MTR's Build up http://www.yotatech.com/showthread.php?t=104000
Need Toyota Parts? www.davezoffroadperformance.com
Quote:
...why does my IFS have no flex, and what can I do to make it flex???
UKMyers is offline
Old 02-04-2003, 10:32 AM   #7 (permalink)
hmm...i guess its not making a noise...the waa waa waa is the vibration or shaking manor(know what i mean?) any ideas on what to do?
__________________
SOLD??? Never
PICS
-Corey
Old 02-04-2003, 10:42 AM   #8 (permalink)
Staff
UKMyers's Avatar
Crawl under your truck and grab the driveline with both hands and see if you can feel any excessive slack in it when you try and turn it from side to side. Make sure you have it in gear. It should feel pretty solid if you get any slop try and locate it and go from there.
__________________
UKMyers is offline
Old 02-04-2003, 10:03 PM   #9 (permalink)
ok..i did this tonight after work..and its solid. i looked at the u-joints and they didnt look bad..but im know things arent always as they appear. what do i do now?
__________________
SOLD??? Never
PICS
-Corey
Old 02-06-2003, 06:55 AM   #10 (permalink)
__________________
SOLD??? Never
PICS
-Corey
Old 02-06-2003, 07:10 AM   #11 (permalink)
PirateFins's Avatar
Send a message via AIM to PirateFins Send a message via Yahoo to PirateFins
When is the last time you rotated the tires? Sometimes the tires from not being rotated/balanced/air pressure maintained frequently wear uneven. You might be noticing the noise more frequently when "slowing down" because the weight transfer from back to front causes the tires to become pre-loaded and any imperfections (flat spots, cupping) can cause the noise you are describing. I have a similar noise problem on my explorer with Goodyears. Started to rotate the tires every other oil change and the noise has almost disapeared. Just a thought.
__________________
Brad
Work is for those who don't know how to plunder!!
Quote:
Originally Posted by habanero View Post
I'd experience an O so big it'd show up on the richter scale.
92x-cab dlx 4x4 22RE, Pacesetter header, everything else is so stock it's not funny, cause I don't have the money!
04 F150 FX4 SuperCrew
PirateFins is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Whats wrong with my suspension? Wazioc General Vehicle Related Topics (Non Year Related) 8 07-09-2006 03:20 PM
Any ideas of whats wrong?? Need Help! JrodNikls Maintenance & Repair Archives 6 07-19-2005 06:39 PM
Whats wrong with my speedo? Mudfreak 95.5-2004 Tacomas & 96-2002 4Runners 2 09-13-2004 11:24 AM
whats wrong with this picture? DravisAR 95.5-2004 Tacomas & 96-2002 4Runners 19 01-14-2004 05:29 PM
HELP, Whats wrong with my 4Runner?? SLC Punk 95.5-2004 Tacomas & 96-2002 4Runners 9 10-23-2002 02:27 PM
2009 InternetBrands, Inc.
