What is this wire for?
Old 07-06-2006, 06:10 AM
mt_goat's Avatar
I'ts on a 2001 5VZFE, I got the intake off to put the supercharger on and there is this little short wire:
http://community.webshots.com/photo/...42310107myszCL
I'm wondering if it is a knock sensor wire, because I remember on the 3.0 it was a good idea to replace it anytime you did the headgaskets.
Old 07-06-2006, 06:16 AM
Beast's Avatar
was it hooked up before
toyota has "extra" plugs
check in your wiring diagram and id the color code
Old 07-06-2006, 06:29 AM
MTL_4runner's Avatar
That's the ECT (engine coolant temperature) sensor wire.
Knock sensors are under the lower intake plenum.
Old 07-06-2006, 06:31 AM
mt_goat's Avatar
Yes it was connected to the engine harness near the where the fuel injector plugs are. I know how to hook it back up, but I'm wondering if it is a knock sensor wire and should be replaced. The fact that it is only about 4 inches long and has plugs at both ends makes me suspect it is meant to be replaced like the knock sensor wires on the 3.0?
Old 07-06-2006, 06:34 AM
mt_goat's Avatar
Knock sensor is under the lower intake plenum.
Oh thanks Jamie, anyone replacing these or will they last a long time?
Old 07-06-2006, 06:37 AM
I'd leave it, but you can take it out and test it in a pot of hot water and measure the resistance (from the terminal to the body of the sensor) if you are concerned about it. The sensor should be fairly linear in resistance change vs water temp.
Old 07-06-2006, 06:43 AM
mt_goat's Avatar
Ok thanks Jamie, I won't worry about it.
sanctfy
All Other Toyota Swaps
09-15-2015 02:52 PM
ToyoToler
08-08-2015 08:43 AM
Daneums
07-28-2015 11:57 AM
TDonkey
07-26-2015 10:14 AM
80Truck
07-24-2015 03:12 PM
Quick Reply: What is this wire for?
