What should I use to clean my MAF
Old 07-12-2005, 11:12 PM
node's Avatar
I just replaced the MAF on my 3.4L. It appears the MAF was in a very dusty dirty environment.
What do you guys use to clean your MAF sensors?
Old 07-13-2005, 03:43 AM
kdx2000's Avatar
I took the two screws that hold the MAF in place and removed it, cleaned it with a q-tip and rubbing alcohol. Just be careful not to use too much pressure. You will be amazed how much crud comes off on the q-tip!
Old 07-13-2005, 04:48 AM
MTL_4runner's Avatar
You can use electrical contact cleaner or rubbing alcohol but the method to clean the sensor will depend on what year motor this is. If you have a 99+ then the sensor is easily accessible and be cleaned as mentioned above, but on 96-98 motors, you can't clean it with a q-tip very easily (just need to soak it in the cleaner repeatedly).
This might help for 96-98:
http://www.4x4wire.com/forums/showfl...rue#Post106649
....or for 99+:
http://www.4x4wire.com/toyota/mainte...tenancep5.html
Old 07-13-2005, 08:21 AM
humanoid's Avatar
Do not clean it with a q-tip becuase you risk the chance of damaging the hot wires without knowing it and your wallet will lighter by a few Benjamins. Just spray it librally by following the procedure on the 4x4wire.com site and just let it air dry and slap the puppy back on.
Old 07-13-2005, 08:37 AM
BajaRunner's Avatar
I used "CRC" Electrical contact cleaner. You get it at the hardware store...or computer part stores will have it too.
Old 07-13-2005, 09:19 AM
Intrepid's Avatar
That is what I used, I would also highly suggest not using a q tip, just spray it and let it dry, repeat if necessary.
Old 07-13-2005, 02:35 PM
node's Avatar
Cool, thanks fellas.
Ill give it a try
smthwsn357
05-01-2024 07:28 AM
mussy01
12-13-2016 08:20 PM
TACOJO
11-27-2015 05:26 PM
Stull
08-28-2015 05:53 AM
Koolbananass
08-12-2015 01:59 AM
Quick Reply: What should I use to clean my MAF
