Old 04-21-2016, 03:20 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Tire Repair and Maintenance
Print Wikipost
what P.S.I. do you fill to?
Old 08-16-2003, 09:06 PM
  #41
Y2Krunner's Avatar
Tire guys-> What is the lowest PSI you can go for offroad (ie snow) with normal A/T tires without risk of problems?
Old 08-16-2003, 10:12 PM
  #42
L33T35T 4Runner's Avatar
I ran my Wrangler GSAs in the sand at 4psi. you could probably go to 3psi if you really feel like pushing it. just dont do any crazy turns at that speed, or else you could break/spin a bead, not pretty.
i think 10 would be good for snow.
Old 08-16-2003, 10:18 PM
  #43
Fink's Avatar
I have never even thought of going that low, my 4-wheeler runs at 20 psi all the way around...that just seems weird to me.
Old 08-17-2003, 09:15 AM
  #44
Mad Chemist's Avatar
I think in sand or snow, you're okay going below 10 PSI for sure. However, for any type of rock crawling/forest offroading, I'd be leary about getting below 10. I air down to ~15 for the most part. You're alot more likely to get your vehicle on crazy angles and break a bead, and higher tire pressure will help prevent that.
Old 08-17-2003, 12:08 PM
  #45
Bumpin' Yota's Avatar
YIKES!! Now that is WAAAAY high for a 4wheeler! All 4 of our 4wheelers (mid '80 hondas) would need btwn 2.5psi and 5psi tops. 25-35psi was for seating the beads to the rims. Read the side of the tire it'll tell ya.
Old 08-17-2003, 03:54 PM
  #46
tires pressure
I run 18 p.s.i. on the road and air down to 6/7 p.s.i when offroad. i'm also running 36"x12.50x15. T.s.l sx's biased ply tires.
Dale Johnston
11
10-31-2015 10:22 PM
irv
10-01-2015 09:49 PM
charlie_fong
09-27-2015 10:06 PM
Armstrong486
09-19-2015 12:37 AM
eggens
09-05-2015 12:16 AM
Quick Reply: what P.S.I. do you fill to?
