What is normal oil pressure?
Old 03-17-2009, 05:11 PM
sfm7315's Avatar
Hello all, just had dealership change oil sending unit on my 98 4Runner Limited because oil light turning on.
They said oil pressure was: 8.1psi at idle-----normal
20-30 at 3000rpm--- below normal according to them it should be at 43minimum, is that true? and if so what could be causes?
Old 01-08-2012, 11:03 AM
Running Down Wind's Avatar
I know this thread is super old, but does anyone know what the stock oil pressure is for a 5vzfe?
Old 01-08-2012, 11:42 AM
babyjack's Avatar
We have a 99 5VZFE that was doing the same thing 2 weeks ago. I hooked a manual gauge up to it and was getting 15-20 PSI while driving. It would then drop to ZERO. I tried the engine flush, found at you local auto place, which helped some. When I drained the oil after the flush was added, I found small bits of sludge. Took a wire with a small 90deg bend and inserted it into the oil pan and managed to find the problem....more sludge. Removed the front diff so I could remove the oil pan and inspect further. Cleaned everything up and put her back together...all is good now. Hope this helps.
Old 01-08-2012, 11:59 AM
Sooooo, what is the factory oil pressure again?
Edit: Never mind. I downloaded the factory service manual. The answer is 4.5psi or greater at idle and 36-75psi at 3000rpm. Hopefully this helps someone in the future.
Old 01-08-2012, 02:19 PM
babyjack's Avatar
I should pay a bit more attention to the date of post! Well, looks like you found your answer.
bigjstang
08-25-2021 12:41 AM
calderp
Engine Swaps
08-16-2016 05:15 PM
calderp
07-27-2015 09:58 AM
Odin
07-15-2015 09:28 PM
88yodabasket
07-13-2015 01:32 PM
Quick Reply: What is normal oil pressure?
