what can happen if i use the wrong grease?
Old Apr 27, 2008 | 05:21 PM
derK's Avatar
i'm going to grease my driveshaft tomorrow and i checked my owners manual and it recommends NLGI #2 LITHIUM grease for the u-joints and NLGI #2 MOLY grease for the yoke and double carden joints....
what happens if i only use for example the lithium on all joints??? will it bind, will it slip, will it sieze??
of course i want to maintain my truck the proper way but is there really a difference and will it be that much more beneficial to use the proper lube for the propery joints?? in my mind as long as it's greased it should be good.
Should i buy the 2 different types of grease?? is it worth it??
Thanks!
Old Apr 27, 2008 | 05:34 PM
bob200587's Avatar
probably not gonna be a big deal. I greased my drivetrain yesterday and I used that green grease for everything. And before that, I don't even know what I used....I've had no slippage binding or any other trouble.
I don't think it would be worth it especially if you only have one grease gun, you'll only use a little bit of the one type....and probably loose a bit of it when changing tubes.
Old Apr 27, 2008 | 11:17 PM
hiloracerboy84's Avatar
i say just go with some marine grease so itll stay on there for a while. i dont see why any kind of grease wouldnt work for those apps. if the parts were more finicky, then maybe stick to the recommendations, but i think either is fine
Old Apr 29, 2008 | 10:31 AM
skjos's Avatar
I used this stuff at all locations:
http://www.amsoil.com/storefront/grg.aspx
It doesn't have moly, but it seems to work fine.
I'm no expert, so I'm also curious if this will cause any long-term problems.
Old May 1, 2008 | 06:04 AM
cackalak han's Avatar
I've always wondered why it called for 2 kinds of grease. Can't see any of those parts being that sensitive to a different kind of grease.
Personally, I just use whatever's in the grease gun (usually, the red general use grease).
Peevedkitten
11
Aug 31, 2015 06:57 PM
AppalachianOffRoader
Aug 12, 2015 12:55 PM
Tonetrk
Aug 6, 2015 10:06 AM
pyramid
Jul 29, 2015 06:53 AM
