weird engine noise
Old Nov 16, 2004 | 09:56 AM
lee's Avatar
lee
weird engine noise
please help me identify the following sounds:
SOUND #1:
CHOOK CHOOK CHOOK CHOOK CHOOK
continuously. i noticed it once it started to get cold out, and its gone away here and there, but its the most obnoxious thing ever, as i can feel the slight vibration in the steering wheel.
i tried turning the heat off, thinking maybe its noisy like the a/c unit, but its not heater-related.
SOUND #2:
for some reason, this weird airy sound has been emitting from what i can only assume is the transmission. whenever i accelerate (hit the gas pedal at all) it makes a sort of whispy, asthmatic noise.
any ideas???
thanks dudes.
Old Nov 16, 2004 | 09:58 AM
blink's Avatar
lee does sound #1 go away after time?
Old Nov 16, 2004 | 10:01 AM
lee's Avatar
lee
intermittently, but im not positive. i try so hard to drown it out with music, that i think sometimes i feel like its gone when its not.
Old Nov 16, 2004 | 06:07 PM
lee's Avatar
lee
bump?
Old Nov 16, 2004 | 07:05 PM
bigbadktm's Avatar
i get a weird sound at certain speeds/rpms. kinda like that first one. i cant describe it, its like a warbling. i get it when i let off the throttle and barely touch the gas. if somebody has a clue, i would love to know what that sound is too.
Old Nov 16, 2004 | 07:58 PM
02SE's Avatar
I get a noise that could be what your sound #1 is.
When it's cold, and humid, a little rust forms on the exposed portion of the belt pulleys, and the belts make noise, until the light rust is worn off.
When it's warm and dry, this doesn't happen.
Old Nov 17, 2004 | 04:58 AM
lee's Avatar
lee
that could indeed be it.
i have a belt that needs to be changed anyhow, im gonna go ahead and do that, see if it goes away.
im really annoyed by that transmission sound (#2)... no idea what that is. its this wispy, airy, asthmatic almost grind (like a light grind) that goes on with every push of the gas pedal...
i gotta get rid of it!
Old Nov 17, 2004 | 07:39 AM
User 051420's Avatar
That reminds me of my exhaust leak........
Old Nov 17, 2004 | 08:23 AM
lee's Avatar
lee
could you hear that inside the cabin, all windows closed, air off, radio off?
it actually changes in severity... sometimes being ridiculously obvious, other times its less easy to identify.
god these two issues are irking me!
Old Nov 17, 2004 | 08:24 AM
lee's Avatar
lee
to make matters worse, i have a freakin' pebble caught in the tread of my front driver side tire, making for an annoying ticking noise too!
Old Nov 17, 2004 | 08:52 AM
I think I can....I'll let ya know.
Old Nov 21, 2004 | 08:34 PM
lee's Avatar
lee
to update:
noise 1 is a loose bearing, so sayeth the dude i trust its not so bad, and i dont mind it.
noise 2 has completely gone away with absolutely no reason. it disappeared the day i brought the truck in and hasnt returned.
as i said... weird!
razorman8669
Jul 12, 2015 12:13 PM
jon.r
Jul 11, 2015 03:34 PM
smiley52
Jul 11, 2015 05:16 AM
Poncho0206
Jul 10, 2015 06:21 PM
Gamble_STi
Jul 7, 2015 07:54 PM
