Waterpump or thermostat? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-14-2005, 01:08 AM   #1 (permalink)
Question Waterpump or thermostat?
If I overheat at idle after a couple of minutes but cool back down when moving, which do guys think it could be, waterpump or thermostat? How could I test either one?
I just replaced the fan and fan clutch for the third freakin time and am desperate to try something else to see if it will stop the overheating. Truck didn't overheat before i decided to change the old and somewhat leaky fan clutch (which was probably engaged all the time).
thanks,
shawn
mightyhye is offline
Old 09-14-2005, 01:16 AM   #2 (permalink)
jimbo74's Avatar
Send a message via AIM to jimbo74
is the water boiling, getting warm, or what? if it is boiling, stop driving it, head damage will occur...
jimbo74 is offline
Old 09-14-2005, 01:17 AM   #3 (permalink)
Elton's Avatar
Send a message via AIM to Elton Send a message via MSN to Elton
i would try a thermostat first to test it u have to boil it in some water to
what ever temp it is if it opens its fine
__________________
My Truck 98 4runner SR5 3.4L 5spd 4x4 E-Locker Mods
Mom 07 Tundra d-cab limited 5.7L 4x4 auto
sister 92 pickup SR5 X-cab 3.0L 5spd 4x4
Papa 89 Pickup SR5 X-cab 4x4 3.0L 5spd/98 4runner SR5 4x4 auto 3.4L
R.I.P 91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06 My Wreck
Elton is offline
Old 09-14-2005, 01:18 AM   #4 (permalink)
jimbo74's Avatar
jsut htought of something else... there are ways to test the thermostat... or jsut replace it, they are cheap..... my truck didnt have a thermostat when i got it... ran cool until summer..... then it started getting hot...... from the research i did... it was becasue the water was actually flowing through the system so fast because there was no thermostat, that it wasnt in the radiator long enough to cool down
jimbo74 is offline
Old 09-14-2005, 09:12 AM   #5 (permalink)
bump cause I need some serious help!
Old 09-14-2005, 09:16 AM   #6 (permalink)
DudeBud's Avatar
Send a message via AIM to DudeBud Send a message via MSN to DudeBud
Quote:
touch the bottem hose when the motor is hot and see if the hose is cold if it is then the tstat is crap.had the same problem ended up being the tstat
__________________
Dan
95 4runner 3vze A/T
84 4runner sr5 Ford 302
T-18 4spd yota t-case
yota front and rear both open
37X13.00 boggers
88 4runner 22re 5spd
DudeBud is offline
Old 09-14-2005, 03:22 PM   #7 (permalink)
Nic
Nic's Avatar
It might be the thermostat or water pump. The thermostat is easy enough to replace. It could be neither. Your radiator may be partially clogged. Just thought I would throw that in.
__________________
Nic
1997 Tacoma 4X4 Xtra Cab 2.7L 5 speed
Nic is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Chicago Waterpump Help GM TURBO General Vehicle Related Topics (Non Year Related) 7 02-18-2006 06:10 AM
Waterpump kawicowboy 95.5-2004 Tacomas & 96-2002 4Runners 3 01-12-2006 05:28 PM
Waterpump question Sludge 95.5-2004 Tacomas & 96-2002 4Runners 4 08-18-2005 09:55 PM
well, my waterpump took a dump Mikronized 95.5-2004 Tacomas & 96-2002 4Runners 14 03-17-2005 05:47 PM
Waterpump Woohs HBoss Maintenance & Repair Archives 12 06-04-2004 03:10 PM
2009 InternetBrands, Inc.
