Vibration when clutch petal is pushed in...
Old 01-10-2009, 10:26 AM
PDCCD's Avatar
-I've only had this truck for two weeks, previous owner didn't appear to take good care of it, no idea of maintenance history.
-220k on a 2.7 5spd 4runner
-I've mostly driven it around town, but on a recent highway trip i noticed a very odd sound/vibration at higher speeds when i push in the clutch pedal. It's like i'm hitting the rumble strip on the side of the road (but i'm not). Low rumble noise and vibration. This only seems to occur at highway speeds, and only when i depress the pedal to down shift.
I've read 5 pages of threads on vibration, but didn't see anything about rumble when the clutch pedal is pushed in.
thanks for any help anyone can extend.
Pete
Old 01-11-2009, 08:02 AM
Ron Helmuth's Avatar
I am no mechanic and the advice is free so take it for what it is worth.
I believe you are describing a worn "throwout bearing" and it is a clear sign the clutch is ready for rebuild. Best to get it taken care of before it fails completely and leaves you stranded, unless you have alternative transportation.
Certainly any tranny shop out to be able to confirm. Err make that any transmission shop.
Put your location and vehicle description within your sign on or signature-could be someone right down the road from you will jump in and volunteer a reputable shop or offer to help you do it yourself.
Mine is overkill of course- but then I don't have to redescribe the vehicle each time and folks in metro Denver will often Private message me to tell me "where to go" heh heh
Old 01-11-2009, 08:33 AM
97ltd4x4's Avatar
Sounds like a throw out bearing...If you replace the clutch assembly make sure you surface the flywheel and replace the rear main oil seal as well.
Old 01-11-2009, 10:43 AM
PDCCD's Avatar
Thanks Guys! I'll add that info as suggested Ron, and thanks for the extra advice 97ltd.
Pete
Old 01-12-2009, 10:02 AM
hross14's Avatar
I third and forth the above posts--throw out bearing.
Old 01-12-2009, 01:21 PM
way to go Pete-now the other southern Mainers can tell you "where to go"
I am sure we got some other folks in Portland (ME) and (OR) for that matter....
93toyoguy
3.4 Swaps
10
09-18-2015 04:16 PM
old87yota
09-09-2015 12:39 PM
Squigglez
09-04-2015 07:33 AM
Nick Berg
09-03-2015 04:36 AM
Quick Reply: Vibration when clutch petal is pushed in...
