used 6.5 qts of oil in 4runner v8
Old 09-24-2003, 05:38 PM
ron717
Guest
Posts: n/a
Per the owners maual, I installed 6.5 qts of 5w30 oil plus new filter in my v8 4runner.
The oil level is at the full mark on the dip stick My question is what is ok on the dip stick? The manual sais it could be between the two dots. That is about a .25 qt of oil. Which is better, full or between the 2 dots?
Old 09-24-2003, 05:51 PM
EricM's Avatar
My vote would be "full" (top dot on the dipstick). Engines all use some oil so why not have the full range (between the dots) available for "consumption"?
Old 09-24-2003, 06:22 PM
CTB
CTB's Avatar
Fill it up to the Full mark, but don't let it fall below the last dot!
Old 09-24-2003, 06:38 PM
44Runner's Avatar
if you wheel it definately go to the full mark...
Old 09-24-2003, 07:48 PM
kyle_22r's Avatar
i believe in between the dots is 1 quart. maybe you meant .25 gallons? or maybe they just changed something behind my back
Old 09-24-2003, 08:11 PM
TechWrench's Avatar
Re: used 6.5 qts of oil in 4runner v8
The manual means that any reading that is between the dots is OK. If it gets lower than the bottom dot, it's time to add oil. But I would also agree that full to the upper dot is better, especially if you spend any time driving in a non-level position.
Old 09-25-2003, 06:31 AM
Sac State's Avatar
What brand and flavor did you use?
Old 09-25-2003, 06:42 AM
kaneman23's Avatar
I fill mine to the full mark. Sometimes it takes 7 quarts to get there on mine.
bigjstang
08-25-2021 12:41 AM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
Colington
03-08-2020 09:51 AM
Gamble_STi
07-07-2015 07:54 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: used 6.5 qts of oil in 4runner v8
