Unsolved Mystery...help AGAIN please!
Old Feb 15, 2005 | 05:28 AM
gohawks's Avatar
Dang, thought I had it fixed. My reverse/back up lights were not working. I installed a new neutral start switch and Wa laaaa!!! Let there be back up lights...case solved! Until last night I noticed they were not working again. Then this morning they were back on WTF!!!!!!
I have an 88 4runner SR5 V6 automatic tranny. Guess I have to start with this all over again...goldurnit!
Any thoughts?
http://img.photobucket.com/albums/v6...9884Runner.jpg
Old Feb 15, 2005 | 06:34 AM
gohawks's Avatar
no suggestions???? bumb
Old Feb 15, 2005 | 11:40 AM
gohawks's Avatar
ok after they worked again this morning they were not working again when I went out for lunch...what gives??????
Old Feb 15, 2005 | 01:06 PM
Injohneer's Avatar
You sure you didn't just need to jiggle the shifter? A ton of vehicles I've driven have a sticky switch that has to be hit just right to make the rev. lights come on.
Old Feb 15, 2005 | 03:01 PM
dragon564's Avatar
Could the connections for the wires at the rev lights be flakey?????
Old Feb 15, 2005 | 05:09 PM
gohawks's Avatar
hmmmm......not sure..and the lights are so dim it is tough to tell if they are on without someone behind me to look...we'll see what happens and if I get time to fiddle with it AGAIN!!!!
Old Feb 15, 2005 | 08:02 PM
wrenchmonster's Avatar
If all your wires are correct, good continuity, no shorts, good connections to light assemblies, good pwr and ground, etc. Then I'd look at the switch again. A lot of these types of switches have clearance adjustments to get it right. Take the switch off and operate by hand. Does it work each and every time? Just a thought from a guy passing through.
-Wrench
Old Feb 16, 2005 | 04:49 AM
gohawks's Avatar
Thanks for that bit of advice. I have to admit I am not the most technically sound person. When I replaced the switch a month ago I had a buddy basically do it for me. If i'm feeling lucky I might crawl under there and mess with it.
coltonstewart
Jun 30, 2011 09:44 PM
894x4oner
Jan 9, 2009 08:29 PM
