Turn signal not working???
Old 11-12-2005, 04:40 PM
JRunner90's Avatar
I tried searching for some info but I couldn't find anything! Well when I turn my turn signals to the left or right they don't work on my 1990 4runner. I've checked all the fuses and they're all good. I also I turned my hazards on the lights blink fine! What else could it be??
Old 11-12-2005, 07:06 PM
4Crawler's Avatar
Could be the turn signal switch itself, dirty contacts inside it. I think the flasher is shared between the turn signal and hazard function, only difference is the path the current takes to the turn signal bulbs.
Old 11-12-2005, 10:07 PM
Elton's Avatar
check the bulbs mine work them self lose i give them a tap and the work fine may need to clean the socket contacts too
Old 11-13-2005, 09:02 AM
JRunner90's Avatar
Alright imma try to clean that out and see if that works!!! Thanks for the info guys!!!
Old 11-18-2005, 10:20 AM
JRunner90's Avatar
Well, I finnaly got it to work! It was the fuse, it wasn't bad though, it just didn't have a good connection! I just twisted the fuses out a little bit so there would be contact and it works great now!
Old 02-24-2009, 07:10 PM
CHIVA's Avatar
Hi i need some help my 95 toyota turn signal and flasher lights not working all fuses ok what can i do.
06-01-2021 01:51 PM
colinmil
07-06-2015 04:03 PM
HRDC0R19
07-05-2015 06:43 PM
aciorba23
06-29-2015 04:18 PM
infinityisfive
06-16-2015 06:51 PM
Quick Reply: Turn signal not working???
