turn signal burnout
Old 03-24-2003, 07:38 AM
Churnd's Avatar
turn signal burnout
One of my turn signals has burnt out. I took it off to see if it was a bad connection, but I wasn't that lucky. I also couldn't see anywhere to could replace the bulb, so I guess I gotta order a new enclosure with the light in it? If that's true, how much are these things?
EDIT:
Sorry, guys... I had a brain fart. It's the drivers side front turn signal.
Old 03-24-2003, 07:45 AM
jx94148's Avatar
You can get to the bulb with a phillips screwdriver. In the rear you undo 6 screws to remove the taillight assembly and then remove the lenses from that, the bulbs can be changed from there. Up front its 2 screws that remove the whole light, the lens will probably fall off and you can then change the bulb.
Old 03-24-2003, 07:50 AM
Co-Founder/Administrator
Staff
Corey's Avatar
Churnd, your turn signals are just like mine, the long yellow ones on the front bumper.
I finally had one burn out for the first time a few months back.
I could tell as when I put the blinker of for the left, it flashed real fast inside on the dash, but not outside.
Just pull off the cover with the two screws, and the bulb twists out of a plastic encasing.
Freshly scanned on my PC.
http://www.pnw4runners.net/tech/91_bulbs.jpg
PS, I was not sure if you meant front or rear since you did not state.
Old 03-24-2003, 09:37 AM
Churnd's Avatar
Thanks for the help guys! Corey, thanks for the scan... that helps alot. I'm about to run to the parts store and get a bulb.
ghostmoney
01-28-2018 11:42 AM
Shoua
13
05-22-2016 05:19 AM
Dennisx2
08-10-2015 06:48 AM
Dennisx2
08-04-2015 01:26 PM
PopsDad1
07-30-2015 02:21 PM
Quick Reply: turn signal burnout
