| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Turbo Question
#2 (permalink) |
Besides the turbo itself, you'll need to get some low-compression turbo pistons (or be prepared for massive amounts of detonation), the ECU from a turbo truck as well as the wiring harness, injectors, and miscellaneous senders, etc. Also, you'll have to add the oil line from the block to the turbo or work out your own turbo oiling. It is not the easy swap that so many seem to think it is.
__________________
Dave Currently own no Toyotas :( |
#3 (permalink) |
i dont know about the compatibility withe newer 4cyl motors, but a turbo is not a bolt on system, you'll need alot more than just the turbocharger to make it a reliable daily driver
__________________
Jeremy, 94 4Runner Turbo Leaf Spring SAS front - Coilover 4link rear (starts December) / Supra Swap My Truck is featured on Supracharged.com - Home of the original Supra swap and Forum One of two things will happen, I will die, or the truck will be finished. I'm not sure which will be first. |
#4 (permalink) |
probably better off doing a supra swap if you want a turbo..........much better power anyway and probably the same amount of work to do the swap
__________________
2004 Tacoma SR5 D-Cab 4x4 3.4L Auto 2001 4Runner SR5 4x4 3.4L 4-Auto |
#5 (permalink) |
hmm well I don't know what to do now. I just found an 86 turbo truck for $500.
#6 (permalink) |
thats a helluva deal on a turbo truck, is it wrecked or something? I'll buy the transmission off you if you dont need it
__________________
#7 (permalink) |
Yeah I saw one go on ebay for 8300.$ 52K miles on the 86 i believe.
#8 (permalink) | |
Quote:
__________________
#9 (permalink) |
it wont pass emissions that way though... well at least it wouldnt here in CA..... but the whole drivetrain swap sounds like a much better idea than a turbo swap only...
#10 (permalink) |
hey jason
short answer - get the truck long answer - start by checking this out: http://www.turbotoys.net select FAQ, then General Questions, then select 2) should tell you exactly what you need to know then the links from that site will get you started there's a separate forum for 22r-te owners (yahoo) as well jm2c hth cheers chris lotus turbo esprit owner imminent turbo 4runner sr-5 owner Last edited by emotepix; 07-18-2004 at 10:57 PM. |
#11 (permalink) |
Well guess I'll call the guy and see if he still has it. I guess I could always resell it here if I decide not to swap drive trains or part it out or something.
#12 (permalink) |
this is one area i think i can help ya man.. i actually build supercharged and turboed 22re engines. an 86 turbo can be adapted to a 94 22ref but like it was said before you will need to either replace your PCM, or if you have the knowledge to reprogram yours to account for the oiling you will need for your new turbo.. there are some bottom end parts you will need along with a boost controller, upgraded spark, and probably new injectors. good luck with your install.. ill be checking in from time to time to see if i can lend you a hand anywhere..
rock on, matt
#13 (permalink) |
Motorhead...which is cheaper...s/c or turboing a 1991 22RE? I love the truck, but hate the lack of power.
Thanks,
__________________
2002 Stellar Blue 4Runner Sport Edition Cold Air Intake Magnaflow Exhaust Iridium Sparkplugs Kenwood KDC-MP628 Blaupunkt Separates in all of the doors Two RF P2002 amps Kenwood 12" Subwoofer My baby: Pics |
#14 (permalink) |
if you have the time you will see more power out of a supercharger.. and less problems.. you need to beef up your cam.. crank.. and better fastners. the problem is finding supers.. i get a majority of mine made by a company called Eaton. but along with supering you need to think about putting a MSD ingition system on that will control retarding the ignition. if you have any more questions just post em or email me.. good luck with the engine. o and to answer your question.. its a bit cheaper to supercharge that engine.. mostly because turbos need alot of electronic mods to make em run good.
rock on, matt
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Turbo automatic transmission upgrade question | cchinny | Offroad Tech | 4 | 05-23-2007 06:24 AM |
| Non-Turbo Supra question | HOJU | Off Topic Talk | 6 | 11-24-2005 09:37 AM |
| Turbo/Nos question. | yongxing | Off Topic Talk | 30 | 08-05-2005 11:23 PM |
| My turbo GSR vs. 99 turbo (that's right turbo) M3 | Juggalo | Off Topic Talk | 34 | 05-01-2005 08:13 AM |
| 87 Turbo Check engine light question? | Lonny007 | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 08-04-2003 06:02 PM |
