Tundra top plate same as 3rd gen 4Runner?
Old 01-26-2006, 06:54 PM
4RUNN!N's Avatar
Are the Tundra top-plates for the front struts the same as the 3rd gen 4Runner or interchangeable?
Old 01-26-2006, 09:38 PM
Albuquerque Jim's Avatar
I believe they have a larger pattern...not certain though.
Old 01-26-2006, 09:40 PM
4RUNN!N's Avatar
I was wondering because I will be running the 97 FJ80 front coils in the rear and a 2.75" spacer in front, but the spacer is made for the Tundra and mounts like a top-out on top of the strut. Heres a link to what I will get if it fits the 4runner top plate. http://www.extremetrucktoys.com/tun_lift_2.htm
Old 01-26-2006, 09:50 PM
User 051420's Avatar
You're 100% correct.
Old 01-27-2006, 12:12 AM
4RUNN!N's Avatar
Damn, that sucks. Whats a recommendation for a top-out spacer that will give me approx. 2.5-2.75"?
Old 01-27-2006, 04:02 AM
MTL_4runner's Avatar
Ditto, they are different.
Ask Bamachem or Schaffer for reccomending spacers.
Old 01-27-2006, 10:54 AM
vegaskurt's Avatar
Yeah I can confirm that, I have a set of tundra top plates and they are slightly larger than the 3rd gens. Just enough so that the tundra ones will not fit on a 3rd gen 4runner.
I think daystar has a spacer and stud kit for 2.5" lift that that is a combo top spacer and preload spacer. Probably not what you want.
I think cornfed or toytec would be your only option for a top spacer that big.
Old 01-27-2006, 11:19 AM
Good Times's Avatar
4runnin,
Like I said in your other post, top plate is different. Try Cornfed if you're planning to stay with spacers.
GOod luck
Old 01-28-2006, 06:13 PM
Since there are 3 holes (centering would not be an issue) would drilling slotted holes be an option?
I have not tried this, it's merely a suggestion.
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
msane99
07-11-2015 08:08 PM
HRDC0R19
07-05-2015 06:43 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: Tundra top plate same as 3rd gen 4Runner?
