trouble shifting in 4wd
Old 03-12-2005, 07:54 PM
toyotaoffroad91's Avatar
hey guys my first post on this forum, i came over from 4x4 wire to try to get some help.
My problem is ever since i put my new motor and tranny in i cannot shift 4wd on the fly anymore, when i attempt to shift i can hear the transfer case start to grind. I have ADD and all my vaccuum lines are oriented correct. im not sure what else it could be since ADD really only works on vaccum. My 4wd does work when i stop and shift into it. does anyone know what would cause this. i am getting a code 62 aND 64 for a shift solenoid and lock up solenoid in the transmission, however i can see this having anything to do with the current problem.
Old 03-12-2005, 08:15 PM
superjoe83's Avatar
did the new tranny come from a different truck, the only thing that i can think of is that you got a manual hub truck tranny/tcase and it doesn't have the syncro to spin up the front drive shaft
Jayboy74
10
12-21-2021 08:27 AM
mskalmus
05-28-2017 07:51 AM
skoob
10-15-2015 03:23 PM
mund1011
08-16-2015 07:10 AM
jgwerth
07-16-2015 03:23 PM
Quick Reply: trouble shifting in 4wd
