TRD SC'd 4Runner tested
Originally Posted by cacattack
wow, faster 0-60 time then the porsche
Strange, but if I look at the stock V8 4R that was tested, these numbers are not impressive.
A stock 4R beat 8 sec to 60 (normally 7.8 or so) and beats 16s in the 1/4 (normally 15.8 or so). SO those numbers look all but impressive.
Just to clatify a stock 4R V8 beats a Cayenne S to 60 and trails it very closely in a 1/4. The Cayenne has more HP, but lacks in torque and it weighs almost a 1000lb more.
The Cayenne S isn't the turbo model right sinced the turbo model has been clocked in the 13s plus I think those 1/4 mile numbers may have been recorded at a track (it's possible it was just done with timing equipment and not an actual track at all) with less than ideal conditions since I think V6 SC'd Runners run in the 15s. My guess is that Runner should run 14s at an ideal track.
Originally Posted by lee
no, the cayenne S is the "base" model.
the cayenne turbo is called the cayenne turbo.. believe it or not!
I got my 4Runner (Limited, V8, 4WD) for around $36,000 in Atlanta, internet deal with all the options except the GPS and air suspension. I found the TRD supercharger on ebay for $3700 and installation was $800. Considerably less than the $48,000 that article was quoting. If you get a dealer to install the supercharger, you get the full 5-yr/60,000mi drivetrain warranty with the supercharger. You only get a year if you install it yourself.
Bad news, I already spun a bearing on the supercharger, had it replaced under warranty.
Pitchar
Pitchar
Originally Posted by HaveBlue
Why not get a Toureg and save a few grand?
06-01-2021 01:51 PM
crashburnoveride
07-10-2015 06:39 AM
Jnkml
07-06-2015 01:20 PM
