trd low temp thermostat
does any one have trd thermostat and flex-a-lite electric fan install in a 1996 and up 4runner, will this combination work ? will the fan kick in with the coolant running at a lower temp
I am running the TRD thermostat and a Hayden electric fan. The Hayden electric fan is thermostatically controlled. You can adjust when you want it to turn on. I also have it switched so I can turn it off on the highway.
I am currently putting together several write-ups including a thermostat install. I hope to finish them tomorrow night.
as soon as it stop snowing here and the temp out side is above 40 degrees i will install fan and stock thermostat and see how it will runs, way to cold to work out side right now.
THe heat exchanger is installed on my Escort. Ill be driving it to a job interview tomorrow. I drove it today to find out where the place is. It was an 80 mile round trip plus a few errands afterwords. Another 80+ miles tomorrow and I'll fill up and let you know what results I got on the highway.
That will be awesome! I want to do both on my 4Runner for sure. I've just got to spend the money for the fuel atomizer soon. I've spent a lot of money in the last couple of weeks, so money is running low to say the least.
Chris
Chris
If you move to a lower temp mechanical thermostat, you'll just need to readjust the one on the fan to match the new temp range.
This thread is building mass with info about the fan install.
the1998sr5
15
07-14-2020 08:35 PM
JaredL
03-28-2016 09:08 PM
nframe
3.4 Swaps
08-16-2015 09:03 AM
Toyvana
07-29-2015 10:47 PM
Poncho0206
07-10-2015 06:21 PM
