trd low temp thermostat
Old Feb 16, 2003 | 11:31 AM
boss hog's Avatar
does any one have trd thermostat and flex-a-lite electric fan install in a 1996 and up 4runner, will this combination work ? will the fan kick in with the coolant running at a lower temp
Old Feb 16, 2003 | 11:56 AM
ravencr's Avatar
I need to know about the Thermo install, but I think I found it by searching for thermostat before on this forum. Check it out!
Chris
Old Feb 16, 2003 | 12:15 PM
boss hog's Avatar
thanks ravencr
Old Feb 16, 2003 | 01:27 PM
HaveBlue's Avatar
I am running the TRD thermostat and a Hayden electric fan. The Hayden electric fan is thermostatically controlled. You can adjust when you want it to turn on. I also have it switched so I can turn it off on the highway.
I am currently putting together several write-ups including a thermostat install. I hope to finish them tomorrow night.
Old Feb 16, 2003 | 01:30 PM
ravencr's Avatar
Hey Alan,
Are the write-ups going to include the Fuel Atomizer and heat exchanger? I hope!
Chris
Old Feb 16, 2003 | 02:46 PM
boss hog's Avatar
as soon as it stop snowing here and the temp out side is above 40 degrees i will install fan and stock thermostat and see how it will runs, way to cold to work out side right now.
Old Feb 16, 2003 | 07:18 PM
HaveBlue's Avatar
Yes, Chris, it will include the Fuel Atomizer and probably the heat exchanger, too.
Old Feb 16, 2003 | 07:21 PM
ravencr's Avatar
I can't wait to hear all about both of them. I'm ready to increase my gas mileage through the roof. Let me know!
Chris
Old Feb 16, 2003 | 07:40 PM
HaveBlue's Avatar
THe heat exchanger is installed on my Escort. Ill be driving it to a job interview tomorrow. I drove it today to find out where the place is. It was an 80 mile round trip plus a few errands afterwords. Another 80+ miles tomorrow and I'll fill up and let you know what results I got on the highway.
Old Feb 16, 2003 | 07:42 PM
ravencr's Avatar
That will be awesome! I want to do both on my 4Runner for sure. I've just got to spend the money for the fuel atomizer soon. I've spent a lot of money in the last couple of weeks, so money is running low to say the least.
Chris
Old Feb 16, 2003 | 08:34 PM
midiwall's Avatar
I just got done doing a FLX-210 on a '96 with the stock thermostat, it works fine. (Great even!) The -210 comes with a thermostat, and like HaveBlue said about his Hayden setup, you can adjust it to cycle at a wide range of temps.
If you move to a lower temp mechanical thermostat, you'll just need to readjust the one on the fan to match the new temp range.
This thread is building mass with info about the fan install.
the1998sr5
15
Jul 14, 2020 08:35 PM
JaredL
Mar 28, 2016 09:08 PM
Toyvana
Jul 29, 2015 10:47 PM
Poncho0206
Jul 10, 2015 06:21 PM
