tps or O2 sensor??
Old Oct 6, 2004 | 11:24 AM
Gabe's Avatar
tps or O2 sensor??
Why is my idle all jumpy? I have cleaned the throttle body so I know its not that. And I can't seem to find anything on the TPS for a 3.0. Every search I have looked at has info on the 22re engine. Where is the TPS on the 3.0? The idle jumps mostly at start-up, from 800 rpms to 2000, always eratic. Not the smooth cold start idle either. Perhaps the Oxegen sensors? Any ideas??
Old Oct 6, 2004 | 11:46 AM
Fink's Avatar
There should be a write-up on it in the Tech section, if not there are a lot of people on here that have done it. I had mine cleaned when mine was in the shop because they said they wouldn't charge me so I just went ahead and had it done.
Good luck man,
Fink
Old Oct 6, 2004 | 12:16 PM
4Crawler's Avatar
TPS testing and adjustment for 4- and 6-cyl engines. Hint, the TPS (Throttle Position Sensor) is on the TB (Throttle Body) as it senses how far open (or not) the throttle is.
Old Oct 6, 2004 | 12:54 PM
Nathan Buchanan's Avatar
Try adjusting the main idle speed down. Mine did that after I cleaned my throttle body, and I adjusted the screw. Then it idled fine.
some drunk guy
Aug 3, 2021 06:09 PM
Firefightersink15
Nov 23, 2015 10:32 PM
larrys93pickup
Sep 17, 2015 07:05 PM
sanctfy
Sep 13, 2015 06:33 PM
moparbay
Sep 3, 2015 12:48 PM
