YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 08-23-2003, 07:27 PM   #1 (permalink)
EDGE's Avatar
Send a message via AIM to EDGE
Toyota Trans Fluid or Mobil1 Synthetic
In the owners manual it says to use Toyota Trans Fluid, has anyone used Mobil1 or Toyota Trans Fluid, it also says to use Toyota Coolant, has anyone used other brands being non Toyota.
Just want to know what others are using or current 4th Geners what you plan to use if and when you change the fluids.
Does it also say the same for the 3rd Gens and my 03 ES300 says Toyota Fluid or equivolent (sp)
__________________
2003 ES300
2003 V8 LTD 4Runner
2006 Nissan Maxima SE
EDGE is offline
Sponsored Links
To remove this ad, register today!
Old 08-23-2003, 09:13 PM   #2 (permalink)
'03 ATF and Coolant
I owned a '98 4Runner and replaced the ATF with Mobil 1 early on. The Toyota specification for the ATF was simply "Dexron II". which Mobil 1 ATF met. The stuff worked fine.
However, the Toyota spec for my '03 clearly says "Use only Toyota ATF", so that's what I'll do, in spite of being a major fan of Mobil 1 products. The reason: there's no indication that Mobil 1 ATF is suitable for our '03, and if I were to change, It would appear to void the warranty. Same thing for the antifreeze.
Toyota may be playing games with these specifications to increase sales of their products, but there's no certainty that going with some other brand would provide any benefit or save money, so I'll not try to out-engineer Toyota.
__________________
-Karl
'03 Titanium Limited, 4WD, V-8
Ex '98 4Runner Limited 4WD auto
'07 Porsche GT3
'88 Porsche 911 (For Sale!)
khaug is offline
Old 08-23-2003, 11:01 PM   #3 (permalink)
Woodbert's Avatar
Send a message via AIM to Woodbert
EDGE- I think I read somewhere here something specific about the Toyota pink coolant that makes these engines run at just the right temp.
On a related note, I was in a shop yesterday and saw Redline "Wetter Water" (I think) and it was an additive to the coolant that claimed about 20 degrees cooler running temp. Anyone ever heard of this stuff or used it?
Here's one link http://www.yotatech.com/showthread.p...yota+ coolant and I think I just answered my own question as well.
96-Runner- What ratio of the redline water wetter vs water vs coolant do you use? Does it really cool the engine as much as claimed? It's hot as hell here as well.
__________________
Woody
"Drive your Dreams"
2003 Dark Blue Mica 4X4 Hilux Surf SSR-G 5VZ-FE V6.
My 2003 HILUX Surf
Checkout My Truck
|Full Leather| |Moon Roof||XREAS| |Rear Torsen LSD| |Mobil 1 Synth Oil| |TRD Sport Oil Filter| |TRD Cat-Back Exhaust||Dueler A/T Revos 265-70-17||THULE/Toyota Lappland 619 Roof Rack/Basket| |Full Husky Liners| |Cee Bailey's Window shades| |Toyota OEM Vent Visors||Griots and Porter "Corey" wax treatment| |Soon: TRD Air Filter|Stay tuned for more...|
2001 Kawasaki 1100 STX DI Jet Ski
"With the right vessel, it easy to get a good crew."
1993 Hilux Surf SSR-G "Sold"
Woodbert is offline
Old 08-24-2003, 04:16 AM   #4 (permalink)
Victor's Avatar
Toyota red coolant is low silicate - but I've heard it is completely interchangeable with the normal green stuff. It will turn a nasty brown if you top off with green though. Whatever you do don't use the orange Dex-cool stuff since that will increase wear on your water pump.
__________________
"Turtle" - Green 94 4Runner
Looks like one and about as fast
JDM altimeter/clinometer, 2002 Sport wheels, 265/75r16 MT/R, , OME stabilizer, BJ Spacers, Cruiser Coils, removed sway bars, rattle can paint for all that peeling clearcoat! Lockright front and rear.
Victor is offline
Old 08-24-2003, 05:12 AM   #5 (permalink)
gwhayduke's Avatar
I couldn't find Redline's Water-Wetter here locally, but I did find a CRC product that sounded similar and used it. It appeared to make a difference...but this is El Paso, TX. Temps above 95F are pretty normal in the summer. I question whether you would need any additive in Japan.
__________________
'99 4Runner SR5 4WD, 5-SPEED. Abzug's vehicle for urban expeditions, navigating flash floods and debris flows (try 12-15 inches of rain in one week). It always gets her home.
'95 4Runner LIMITED 4WD, 5-SPEED, over a quarter million on the original 3vze & headgaskets. TRD heavy duty clutch, TRD heavy duty flywheel, OME 900 springs and shocks. This old gal has gotten me out into the field, and back for 8 years, never failed to start or gotten stuck.
gwhayduke is offline
Old 08-24-2003, 05:36 AM   #6 (permalink)
Poul D'eau's Avatar
The new performance products catalog had
Red line water wetter in it.
__________________
Arachnoleptic fit (n.): The frantic dance performed just after you've accidentally walked through a spider web.
08 FJ Cruiser, no mods yet.
72 FJ55 Getting it back to daily driver.
2nd gen. OME steering stablizer, Collander air box mod, Jardine cat back, Bridgestone Revos, OME comfort shocks with OME 900's, Hella 550 fogs and FF 50 driving lights, Uniden 68 elite cb
Poul D'eau is offline
Old 08-24-2003, 06:57 AM   #7 (permalink)
nrgetic99's Avatar
The Toyota genuine fluid is known as T-IV or ("Tee four") for you practical types !
It is a slighter 'harder' fluid than some of the others out there and harder than 95% of the Dex III fluids.
By harder, I mean less friction modification and in the real world, it means shorter shifts. As a gross generalization, shorter shifts invlove quicker lockup, less 'slipping' , less heat and longer life.
Longer shifts are smoother , involve more slipping with slower lockup and more heat into the fluid.
These differences in real terms are probably not evident to the average driver.
When I SC'd my 99, I switched to a full synthetic Dex IIIG fluid, and immediately noticed the slower shift, especially under hard acceleration in 1-2 shift.
I have access to the power flush machine so I switched back to a "Tee Four" fluid and the shifts quickened up. The fluid I used was a full synthetic fluid out of Japan that I got through my work.
Using the often heard "Heat is the biggest killer of transmissions" analogy, especially with my modified 4Runner, I chose the fluid which puts less heat into the fluid.
Anyway, in short, this is one occasion where I would 100% recommend the factory fluid, unlike some cases where it is just marketing and money, this fluid is different . It has some subtle viscosity changes also involving shear stability also but I will not get into that.
Hope this makes sense.....
David
P.S> I just finished helping one of my customers develop an ATF for higher mileage vehicles...it will be in a yellow bottle..hint, hint !
__________________
98 Limited: Taco/Tundra TRD/OME lift, diff drop, LC rims, 32" REVOS, TJM T-17, Magnaflow
93 SR5 V6 4WD *** TOTALLED **OME lift, Aisin hubs, 31x10.5 Dueller ATon 15x8 AR23's, clears, Silverstars, K&N, Dynomax, Yakima ...
03 V8 Sport. Jaos Center Protector, Landmaster Dual beams, Silverstars, RD leather interior , TRD rims/X-Terrains - gone :-(
99 SR5 "Highlander", SC'd, SAW/Downey,32's,Addco,deck plate, TRD cat back, 1.5Kw stereo ...gone , not forgotten
96 SR5 Dune... 1.5kw stereo
nrgetic99 is offline
Old 08-24-2003, 02:11 PM   #8 (permalink)
EDGE's Avatar
So as I figured I'll just use the Toyota Fluid and nrgetic99 you especially cleared up any doubt I had but one question is it safe to use the Toy Trans Fluid in say other vehicles where owners complain the trans shifts to slow between 1st and 2nd
__________________
2003 ES300
2003 V8 LTD 4Runner
EDGE is offline
Old 08-24-2003, 04:53 PM   #9 (permalink)
Woodbert's Avatar
Quote:
gwhayduke,
As of 0830 it's 86F with 74% humidity. Low to mid 90's with a real feel of over 100 daily. Current Naha, Okinawa Weather
__________________
Woody
"Drive your Dreams"
My 2003 HILUX Surf
Checkout My Truck
Woodbert is offline
Old 08-24-2003, 05:48 PM   #10 (permalink)
elnip's Avatar
FYI - Pep Boys here in Cruces has it along with the Fuel Injector Cleaner. I'm running it in my rig.
__________________
FUN TOYS:
'98 4X4 Taco S/C'd Fuel mods, WI almost done...
'97 FZJ80 40th S/C'd Factory lockers CDL
elnip is offline
Old 08-25-2003, 04:34 AM   #11 (permalink)
gwhayduke's Avatar
I would consider mid-90's optional. As for the humidity, it doesn't affect the cooling of your vehicle appreciably, since you're not cooling your engine through evaporation...only through transfer. Now you could look at the ability of air to transfer heat at that humidity and the ability of the fluid to transfer the heat from the block....
Aww just put the Water-Wetter in..
__________________
Old 08-25-2003, 04:58 AM   #12 (permalink)
Woodbert's Avatar
gwhayduke,
Thanks for the information. I really apreciate your input.
__________________
Woody
"Drive your Dreams"
My 2003 HILUX Surf
Checkout My Truck
Woodbert is offline
Old 08-25-2003, 07:13 AM   #13 (permalink)
Junior Member
I used Mobil 1. Had my fluid changed by the dealer, the used the Toyota stuff. Went on a trip two days later and the ATF light came on and I had fluid all over the back of the truck. Brought it back to Toyota and they told me the fluid overheated and that they had seen this before. They changed it to Mobil becauseit is the only thing that wouldn't overheat. This was my old 4Runner a '94.
tpg013 is offline
Old 08-25-2003, 09:10 AM   #14 (permalink)
Highland Runner's Avatar
Here is what I remember from a web site that was comparing coolant. I think this was from a Popular Mechanics, but can't find it now. Always use red Toyota coolant. Many said its the best and even use it in other brand cars. Green is very bad for Toyotas as its silicated and will ruin a Toyotas water pump etc very quickly. The orange Dexcool is very close to the red coolant as its not silcated. The article said it could be put in Toyotas as long as the red is flushed out completely first. The two fluids don't mix well I quess. I remember hearing that some Tacomas were coming from the factory with the orange Dexcool. Don't know if that is true though. I will keep seaching for the coolant web site.
__________________
Chris
Mine-94 SR5 4-Runner, 3.0, 4X4, Aisin Hubs, Yakima Load Warrior, 210k Miles | Wifes-99 Limited
Highland Runner is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Synthetic Transmission fluid jeremys73 General Vehicle Related Topics (Non Year Related) 3 02-11-2006 04:43 PM
Mobil1 5w-30 Synthetic and my 2002 Corolla??? ugadawg95 Off Topic Talk 5 01-22-2004 10:25 AM
?? changing tranny fluid + trans case fluid + diff fluid.... sage 95.5-2004 Tacomas & 96-2002 4Runners 1 06-22-2003 09:38 PM
Best price for Mobil1 Synthetic Oil? Plamar 95.5-2004 Tacomas & 96-2002 4Runners 13 06-09-2003 12:53 PM
Synthetic fluid question obxfishn 95.5-2004 Tacomas & 96-2002 4Runners 8 05-27-2003 02:53 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
