Tow Hook Bolts
Old 01-04-2003, 10:02 AM
HBoss's Avatar
Tow Hook Bolts
There are 2 tow hook bolts that hold the tow hook in under the front passenger bumper in. It seems either the bolts are stripped or whatever's holding it to the frame (i.e. nut) behind has come loose. No matter what, they won't come out now and they won't tighten.
They turn forever and there doesn't appear to be a way to get into the chasis frame to hold the nut while tightening the bolt. The nuts were probably welded on but have come loose for some reason.
Can anyone shed some light on this situation for me with a recommendation? I'd like to be able to get the bolts out, replace my tow hook, and bolt it back on..
Al
Old 01-04-2003, 10:23 AM
Mack's Avatar
As I recall when I took mine out to mount the bush bar they seemed to spin forever.
If they are stripped, maybe you can wedge a prybay in and pull the bolt down while turning in order to get som purchase?
Old 01-04-2003, 12:40 PM
Sludge's Avatar
if the prybar idea dont work you may have to cut the bolt head off and drill out remaining bolt and retap the hole.
Old 01-04-2003, 01:30 PM
martin's Avatar
I believe you are probably right on this one. When I installed my ARB, I had to remove these bolts and they are a pain to remove. They are a fine thread so you might want to make sure they are not moving (the bolts are long - 35-40mm). If they are stripped cut the head and drill out is the method I have always used.
Martin
Old 01-04-2003, 03:25 PM
INsr5runner's Avatar
Martin:
Hey where in Indiana are you? maybe meet up to do some wheelin??
sorry its not on the subject fella's!
Mike
Old 01-04-2003, 04:07 PM
Skydigger's Avatar
I took mine out about a month ago to install the ARB without any problems. I don't remember any nuts just a threaded cross-member.
Good luck,
Warren
Old 01-04-2003, 05:19 PM
martin's Avatar
Mike,
Lafayette. How about yourself? I was planning a trip to the Badlands this weekend, but with the snow I decided to wait.
Martin
montanatruck
02-26-2017 07:07 AM
Scatterbrain
14
08-31-2015 06:26 AM
TJWilly
07-31-2015 02:05 PM
vanion2
07-29-2015 06:17 PM
whereAreMyPants
07-22-2015 03:32 AM
Quick Reply: Tow Hook Bolts
