Tires / shocks wet traction
Old Feb 10, 2005 | 06:41 AM
TacomaTRD's Avatar
For those of you thinking that your tires may have wet traction issues check you shocks.
I am running some Continental LTX tires (no ˟˟˟˟˟ please came with my TRD and are like new) and these tires sucked when it was wet, lots of wheel spin.
Anyways after having my new Billi's sitting in my Basement for over a month I finally put them on this past weekend. Man what a difference with these tires, they hook up like never before. I did rotate the tires when I did the shocks but I don't think that has anything to do with it, tires are very evenly warn.
Picked up my Billi's for $203 delivered from CabePerformance. The only issue I had was they didn't come with new rubbers for the front topside mount, I just had my buddy get me some.
Old Feb 10, 2005 | 07:39 AM
GodwinAustin's Avatar
Just put used billies on my 97 (70k on oem shocks) noticed the same thing this morning.
Old Feb 10, 2005 | 08:10 AM
TacomaTRD's Avatar
my original billi's had 77K on them and they were shot, for $203 from Cabe I would have just bought new unless they were given to you...
Old Feb 10, 2005 | 08:25 AM
yeah - they were given to me - and it was a 25 minute job to switch them out....they seem better than stock though with 45k on them.
I am eventually going with new billies
Old Feb 10, 2005 | 08:28 AM
TacomaTRD's Avatar
you just did the rears then... if you do the fronts don't forget to drop the swaybar links makes getting the shock in/out much easier...
Old Feb 10, 2005 | 08:33 AM
well thats a whole different problem - I opened up my rear storage compartment to get the jack stand - and well - NO jack stand
bought the truck used and havent used the stand yet - apparently the PO forgot to put it back or something
so now - I have to go buy a new one
(thanks for the tip)
Old Feb 10, 2005 | 08:38 AM
TacomaTRD's Avatar
hit a junk yard, I've got a spare one that I scouped when getting some parts for my old 94 I had. you'll also need a spring compressor, I built my own, much easy then those cheap ones you buy...
Old Feb 10, 2005 | 09:08 AM
Junk yard is a good idea - dont need the compressor as the coil and strut are allready together on the old trd setup.
hey man didnt notice you were in NH
This storm is awesome - we needed this.
Old Feb 10, 2005 | 09:18 AM
jimbo74's Avatar
i would say to forget the stock jack... get a cheap floor jack, you will thank me later when you use it... a lot of members here have tried to use the stock jack in an emergency situation only to find that it still doesnt lift the truck high enough to do any good....
Old Feb 10, 2005 | 10:28 AM
slyang1012's Avatar
hey i just bought a high lift and dont need my jack.. u want?
10bucks plus shipping? give u the jack and the little bar to raise it with.. i think theres like two different ones.
Old Feb 10, 2005 | 11:28 AM
TacomaTRD's Avatar
this storm sucks, we got about 2" in manchester and it stopped...
Old Feb 10, 2005 | 11:37 AM
jacksonpt's Avatar
Senior Member
This is just a guess based on my observations, but I think it has to do with the way the body leans and how it affects the weight distribution, especially in turns. I've noticed that with my front swaybar disconnected, I get a lot more wheelspin as the truck dives more in turns.
Old Feb 10, 2005 | 12:15 PM
TacomaTRD's Avatar
sure that has some effects, but I had problems throttling up from a stop light, what was embarrising was my 2.7ltr pulled me hard becuase it could get traction and my TRD couldn't, my buddy was driving the 2.7ltr and was laughing all they way. Now I can throttle it up from a stop light and she hooks up real well. I was beleiving that this was a tire problem since I have never owned these tires before and what I was reading about other tires on one of the tire threads.
BTW which cooper tires are you running? I am looking at the S/T's as a possible replacement for these, even thou I think I can get another 20-30K out of these tires.
djpg2000
Nov 11, 2020 04:56 AM
justdifferentials
Just Differentials
14
Sep 24, 2017 08:32 PM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
Luvmeye22re
Aug 4, 2015 03:53 PM
SMOD
Jul 27, 2015 01:45 PM
