Tires
Old 10-12-2005, 12:16 PM
Citykid's Avatar
Tires
Just spoke with the company that's going to put on my new Revos. Said they put Nitrogen in the tires now, no air. No air pressure flucuation, no need to keep checking air prssure, etc.
Anyone know about this?
Old 10-12-2005, 12:18 PM
jimbo74's Avatar
do a search, its been doen for awhile... yes its good, but you still need to check inflation pressures at least 1 time a month.... because although the nitrogen is awesome, rubber parts leak air and so do valve stems... it isnt something is wrong, but it happens
Old 10-12-2005, 03:20 PM
Flamedx4's Avatar
See if they have helium. Lightening the weight will increase your mileage!!
Old 10-12-2005, 03:30 PM
celica's Avatar
Not entirely correct.
The reason why they use nitrogen is due to the molocule size. Air will more easily pass through hte permiable rubber. Nitrogen takes loger as the molocule size is larger. You will still need to check the tire pressure because it will change with temp, etc. You can top up the tires with regular air. Costco is the main company that uses nitrogen. They have good information on it in their tire shops.
Matt
1uzRunner
63
11-10-2018 03:58 PM
Williamemslie
14
10-05-2015 09:28 AM
AkitaDog
09-03-2015 09:01 PM
128keaton
09-03-2015 05:09 PM
matthew138
09-03-2015 08:21 AM
Quick Reply: Tires
