| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Timing Survey
#2 (permalink) |
Hey,
Right now I have mine set at 8 degrees. I've got some pinging issues I'm trying to figure out and it doesn't ping as much at 8. However, when I get the pinging solved, I'm probably going to set it around 12. As far as the "factory" settings go, the idle should be at 800 and timing at 10 degrees. Well, have fun. ![]() DH6twinotter
__________________
------------------------------------------------ 1990 4Runner: SR5, 2wd, 3.90 rear, 3VZ-E, auto. 15x8 MT classic II rims, 31x10.50 Bridgestone Desert Duellers ($50!), Cobra CB, 3' firestick Planned stuff: Pre-runner light bar with Hella 500s, small lift Stuff I'd do if I went crazy: SAS, 7mgte or 1UZ swap, and as much offroad goodies as $$ will allow. |
#3 (permalink) |
Hey, I have a 94-runner and the sticker under the hood states 10 degrees BTDC. Previously the timing was way off due to a malfunctioning throttle positioning sensor and it seemed to have a lot of power, now with the TPS reset and timing set correctly it pings a little and has slightly less power(may still be due to the TPS as I havent replaced it yet). Either way the correct setting should be 10degrees BTDC. Hope this helps!
matt
__________________
94-runner, 3.0, 5spd, bilsteins, PP springs, Aisin hubs, Hella 500s, Husky liners, OME stabilizer, BJ spacers, Daystar spacers in back. Rockcrawlers with 32-11.5 BFG All-Terrains e-locker and Stubbs sliders pending install |
#4 (permalink) |
yeah it says 10 degrees BTDC in my manual as well ,but some here have said that they advance it a bit ,im not sure what the effect of this is ,doe's it improve response ?
What about Fuel consumtion,I assume its get worse,or am i wrong.???
__________________
Maddog no 4x4 at this time Formerly > 1990 Hilux Surf (4runner) ssr ltd 3.0 V6,auto,31"s,140k km's. |
#5 (permalink) | |
Guest
Quote:
15 degrees advance, 5 degrees over stock, is pretty far, and you start running the risk of preignotion and the resulting engine damage. If you're running high octane fuel, this helps mitigate the enthusiastic advance. But, you may not be doing the jumpering you think you're doing. When you connect to the jumper, the engine should fall down on rpms and run differently within a second or two. You should also see a marked change in timing using a timing light. If you don't see that happening, you've got a fault code that is preventing the computer from responding to the jumpering. So in that case, the timing isn't very far advanced at all (I think it sits at around 12 degrees unjumpered). |
#6 (permalink) | |
Quote:
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Help with Stat survey | Localmotion | Off Topic Talk | 43 | 06-12-2006 08:00 AM |
| engine survey... | V_Runner | 86-95 Trucks & 4Runners | 26 | 03-20-2006 11:27 AM |
| Important Survey I, Please Respond | AznSky | 95.5-2004 Tacomas & 96-2002 4Runners | 64 | 02-14-2005 06:07 AM |
