Timing Abd shimming price for 3.4
Ok so I have a 99 tacoma with the 5vz 3.4 and it's time for the timing belt to be changed and to go ahead and reshim the cams on the driver side. Does anyone have and around about idea of how much this whole job would cost to properly do???
Labor to do a valve adjustment is around 5 and a half hours. Is there a reason you want the valves adjusted? Cause unless their making noise I don't know how you'd figure they need adjustment.
I checked mine at 176k when I installed my surcharger and replaced my valve cover gaskets and mine were fine. I haven't seen too many 3.4's that have needed adjustment. The ones that did were all well past 250k. Is it throwing any codes? Have you kept up on other maintenance like spark plugs and the fuel filter?
Yea everything has been keep up I'm about to go ahead and do the timing filters and plugs with and intake manifold gasket because antifreeze is leaking from it. As far as codes I have none
If the cam timing is off then you probably would throw a code. I was just curious as to why you were condemning the valves as the cause for your issues. Just remember to check the valve clearance when the motor is cold. Other wise your measurements will be off.
It's a possibility. Also, check your mass air flow sensor. Make sure it doesn't look fuzzy or dirty. Also, how are the spark plug wires? Are they factory toyotas? I've seen issues with all toyotas that people put crap aftermarket plug wires on then have issues with miss fires. Also look for carbon tracks running up the coils and the sides of the plugs and wires.
you almost never have to mess with the bucket shims or whatever they called. i pulled a head off and they were all in good shape. do the timing belt yourself. it isn't too bad. just time consuming really. looks harder than it really is. i did it and more myself. if you were in vegas i'd do it for you for a 100. i got the same motor in my t100. love workin on it. but i don't get to very often being a toyota nothin ever breaks. lmao
haha yea same here. i actually need to do a few things too. new half shafts, oil pan leak. but being a 4x4 i haven't wanted to do it in the driveway. got a new job at the dealership so i got lift access now so dropping the front end wont be as bad. i'll do it all at the same time. might also do a manual hub swap too since ill have all that stuff opened up to pull the half shafts out. my cv boots are blown and have been for some time now.
