Thumping Sound
Old 01-13-2003, 07:40 PM
jm47's Avatar
Thumping Sound
Anyone have any ideas/suggestions what is causing an occasional thumping sound along with a slight hesitation coming from the rear axle when I brake or accelerate from a dead stop?There are152000 miles on my 4Runner and I've never had any work done on the transmission/rear end/universal.Thanks in advance.
Old 01-13-2003, 07:56 PM
CTB
CTB's Avatar
Probably won't fix your problem, but it is definitely time to change your tranny fluid and diff fluid.
Old 01-13-2003, 08:26 PM
jx94148's Avatar
Grease your driveshaft at all the grease fittings also. The shaft has the ability to legenthen or shorten slightly and if the splines that allow this are dry they will stick and make noise rather than slide smoothly like they should.
Could also be play in the rear differential gears. To check that set the parking break, block the wheels, put the tranny or transfer in neutral, try to twist the driveshaft by hand. If it moves more than a tiny bit and a clunk can be heard from inside the diff, you have worn diff gears.
Davebarbier
11-03-2015 03:28 PM
Kamaloha
10-16-2015 05:13 PM
Chicken12
10-14-2015 03:54 PM
Flightguy
10-02-2015 05:34 PM
voiddweller
09-28-2015 11:21 PM
Quick Reply: Thumping Sound
