Is there a cat-back for a 2000 other than Jardine and TRD?
Old 11-03-2002, 07:19 PM
INsr5runner's Avatar
Does anyone know if there is another cat-back kit for 2000's besides the Jardine and TRD one? It seems to me that both require the dual cat, which I don't have. Also, any good words about the K&N FIPK filter kit? I was thinking about going with INJEN.
Old 11-03-2002, 07:31 PM
pfdaxe's Avatar
I have a single cat TRD exhaust. They make them for dual and single cats. Stay away from the K&N kit. Not worth the money. Read through some of the other post on this forum regarding exhaust systems and intake systems.
Paul:fireman:
Old 11-03-2002, 07:39 PM
Away
Dr. Zhivago's Avatar
If your truck has only one catalytic converter, you can use the Borla Exhaust for the 96-98 trucks. Same goes for PerformanceProducts and Gibson systems. I'm biased, but I really like my Jardine. You could also have one built for you.
TruckPerformance carries the Borla, Gibson and Jardine systems for the 96-98 models.
Hope this helps.
Dr. Z
Old 11-03-2002, 07:49 PM
Away
I also should mention, in case you haven't seen it, my Mod for the Intake System on your truck. You can view it here.
It's a good read (if I do say so myself). Enjoy!
Dr. Z
Old 11-04-2002, 09:54 AM
go custom
Go to your local neighborhood muffler shop and have them make you a custom Cat-back system. You may be surprised how much cheaper it'll be. I know when I was looking at systems, I didn't want to spend $500-1000 on a "brand name" system.
My local shop made me a 3" Cat-back with muffler for about $150.
Mike
Old 11-04-2002, 11:30 AM
Jason B's Avatar
I also went the custom route and it looks and sound great!
I have a bunch of mpeg videos of my exhaust on my 4Runner page in the pics&vids section.
Old 11-04-2002, 11:59 AM
I was looking at the Jardine, and it isn't that pricey, I was wondering how throaty it sounded though. Also, If I go the custom way, what is a good muffler that growls?
Old 11-04-2002, 12:07 PM
Co-Founder/Administrator
Staff
Corey's Avatar
Ahhh, you need to visit my exhaust page.
http://www.pnw4runners.net/exhaust/exhaust.htm
I don't have the Jardine on the page, but the file is up.
2.1 MB, right click and save file, then play.
http://www.pnw4runners.net/exhaust/jardineexhaust1.mpg
Still, it's cheaper to go to a good exhaust shop and tell them to fab you up a setup like some of us have done.
However, most 3rd gen 4Runners already have 2.25" pipe.
All you would need to do it get a muffler, and have a shop weld it in place.
A good growler is the Vortex, with Magnaflow right behind.
I choose the Magnaflow, and I like it very much.
It sounds way better in person than the vids on the above page.
loosehead's Avatar
Hey INSR5-
Corey, one of the members here, has an exhaust comparison page http://www.pnw4runners.net/exhaust/exhaust.htm with sound clips of several different types of mufflers.
Corey, where are you, did you get the Jardine added to your page yet?
EDIT: Nevermind, he was typing faster than me again...
Old 11-04-2002, 12:17 PM
Staff
Corey's Avatar
He he he, I keep telling everyone.
The secret is to keep a tub of Amsoil grease by the keyboard to dip your fingers into.
It lets you type with lightening speed.
Old 11-04-2002, 12:23 PM
loosehead's Avatar
The secret is to keep a tub of Amsoil grease by the kepboard to dip your fingers into.
LOL...Good advice, Corey, but if I type too fast I tend to :confused:
Old 11-04-2002, 08:10 PM
tomus1000's Avatar
Be advised. The Jardine (the one in the Performance Products catalog) is NOT stainless steel. That is why it isn't as pricy as the others that you looked at. I am not sure what you are going to do with the rig, but a non stainless exhaust would not last very long on my truck. I am constantly neat the beach. The salt water would kill it. Also, here in CT, they spread salt on the roads in the winter. Think about how much corosive stuff your truck will come in contact before you by a non- stainless exhaust.
Noel
Old 11-04-2002, 08:53 PM
Away
Noel
The Jardine system is made of Aluminized Steel. It also carries a lifetime warranty. So, if it does fail, Jardine will replace it.
I had an Aluminized System on my Supra for over 10 years in CA. I ran it thru snow and salted roads quite a bit. I never had any problems with it.
Just my .02
Dr. Z
Old 11-05-2002, 07:54 AM
Does the Jardine Tip need to be welded on? I like the rolled look, and also maybe a 3" tip. .... DR. Z are you sure the '98 model will fit my 2000?
Old 11-05-2002, 08:24 AM
Away
The tip that comes with the Jardine system is attached with a pinch-bolt style fitting. There is an Allen head screw that you tighten to clamp the tip to the tailpipe. The tip is a chrome 3.5" slash cut tip. It is not a rolled tip. I would set up a picture, but I am not at home. You could always get a different tip if you don't like the tip that comes with the system.
Did you look at the vid Corey posted for you to see? That system is on a 2001 Dual Cat truck. If your truck has only ONE catalytic, then yes the 96-98 system will fit on your truck. That is what I am running. It is Jardine part #89215. If you have Dual Cats, the part # is 89218.
Here is Jardine's Website
Hope this helps.
Dr. Z
Old 11-05-2002, 06:24 PM
I did check out that video, and it sounded good! I noticed that the exhaust was a rear exit...the one for the '98 says it is a side exit. was that just a custom modification? I really like the rear exit!
Old 11-05-2002, 06:32 PM
Away
The 96-98 system exits at the rear corner of the bumper. Not really a side exit per-se. But it's not straight out the back either. If you tow stuff, you don't really want a rear exit as it will get soot all over whatever it is you are towing.
I will send you an email with a pic of the system on my truck.
Dr. Z
Edit: Well, since you aren't set up to receive email, I will make another post with a pic of my truck. Hang on.
Old 11-05-2002, 06:50 PM
Away
Okay, here's the exit angle of the Jardine for the 96-00 trucks with a single Catalytic:
Here's a side view of the truck. You can see the Tip at the rear:
You also get to see my dents and dings now too.
Dr. Z
Old 11-05-2002, 07:04 PM
Thanks Dr. Z! you've been most helpful! I think I am going to get the Jardine Exhaust, probably order it this week so I can put it on next weekend, this weekend is too busy, and I don' want to have to finish all my work and stare at the box wishing I could install it!!! how long did it take to put yours on?
p.s. nice truck!
Old 11-05-2002, 07:07 PM
pfdaxe's Avatar
Here's a pic of my single cat TRD exhaust:
Quick Reply: Is there a cat-back for a 2000 other than Jardine and TRD?
