Taurus fan install question....
Old Nov 26, 2004 | 04:51 AM
Marc P's Avatar
Taurus fan install question....now installed!!
I am planning on installing my newly aquired Taurus fan this weekend. I went to my local auto parts store and picked up an adjustable thermostatic fan controller. It comes with a 30amp relay built in. Most of the info I have seen shows people putting up to a 85 amp relay, is this necessary? or will the setup I bought work on its own?
Old Nov 26, 2004 | 07:04 AM
Yoda's Avatar
You got the fan with 3 terminals on it? I would get the bigger relay, at least for the high speed. They draw a lot of amps.
It is usually from a Taurus with the 3.8 engine. There is one in the junk yard near me......hmmmmmm
Old Nov 26, 2004 | 08:07 AM
Marc's Avatar
I have only used the low speed setting with a 25 amp fuse with no overheating problems even with A/C. For what it's worth I went through 2 of the adjustable thermostats before switching to a 185 fixed thermostat.
Old Nov 26, 2004 | 08:45 AM
seafarinman's Avatar
Here is the thread from my Taurus fan install a couple years ago. It has all the part numbers and stuff that I used.
https://www.yotatech.com/forums/show...ght=taurus+fan
Old Nov 26, 2004 | 08:52 AM
RobT2k's Avatar
Why did you go through 2? How were they failing?
Hey Marc P- you don't want to hassle w/this, I'll take everything off your hands for $50 and I'll even pick it up
Those adjustables aren't cheap, that would suck to keep having problems with it.
Old Nov 26, 2004 | 09:01 AM
I went through a couple of them as well. I am on the same fixed 185* as I last swapped in last year. The fixed ones are reliable, why they are more reliable is beyond me. I have a spare fan that I am going to install into my 87 this weekend hopefully.
Old Nov 26, 2004 | 05:44 PM
Marc P's Avatar
So now I am thinking I should return the adjustable one. I really liked the idea of being able to adjust it--especially when wheeling in the hot desert.
Old Nov 26, 2004 | 08:04 PM
RobT2k's Avatar
marcP -the guy who replied to your pirate post included a link to just wire up the higher power line and let the sensor adjust fan speed.
Old Nov 27, 2004 | 04:37 PM
Marc P's Avatar
Fan is installed--pretty easy too. The hardest part was attaching the fan to the radiator. I did it without removing the radiator, but I think it would have been easier if I did. I have it set to come on at 185 degrees, and it stays on all the time with the a/c on.
After I get some miles on it i will give my opinion--so far its great.
coryc85
Sep 9, 2015 06:24 AM
jackiebrownia
Jul 20, 2015 09:02 AM
TURBOrunnerNM
Jul 20, 2015 08:31 AM
1996Taco
Jul 20, 2015 12:02 AM
zd92655
Jul 5, 2015 04:25 PM
