Talk about bad timing
Old 04-06-2004, 08:18 PM
Guest
Tahoe666's Avatar
My timing is advancing itself somehow. I'll use a timing light to put it back to the factory setting and it won't run worth crap. I have to advance it about 50 degrees to get it to run properly, then about 2 days later, it has moved itself again. My timing belt is new, so I cant imagine it has skipped a few teeth. Is my distributor crapping out on me?
Old 04-07-2004, 12:24 PM
AF1
AF1's Avatar
Mine did the same before I had the timing belt and tensioner redone....hope you find out your problem.
Old 04-07-2004, 07:22 PM
AgRunner06's Avatar
It could be your TPS. It controls the timing. Check out this site:
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
The symptoms of a bad or misadjusted one are at the bottom of the page.
Old 04-07-2004, 07:45 PM
Guest
Tahoe666's Avatar
I replaced the TPS today. It seems to be running better. The timming still isn't lining up where it should. I had to time it by ear again. I will give it a couple of days then check to see if the timing has moved again. Thanks for the help.
Old 04-08-2004, 04:00 AM
Babypig's Avatar
depending on how many miles you have i would check the signal generator. It's basically at the end of the wires that go into the distributor. Mine is bad and the timing jumps all over the place. You'll need an ohm meter to check it, but I'll bet it's out of spec. Have you tried pulling diagnostic codes to see if anything comes up? Let us know what happens.
Steve
Old 04-08-2004, 04:10 AM
bikerunner's Avatar
How much was the new TPS, and did you have to get it from the dealership? mine has symptoms of going bad too. Thanks
06-01-2021 01:51 PM
Whatever123
09-30-2015 12:12 AM
colinmil
07-06-2015 04:03 PM
Quick Reply: Talk about bad timing
