Switch from 3" catback to 2.5", performance loss?
Old 08-08-2006, 07:49 PM
MaNiAk's Avatar
I installed a ALL PRO leaf pack and had to cut down my custom exhaust to make it fit. Went to midas and they rerouted my exhaust over the leaf spring. Upon driving fron the shop I noticed a decrease in power. I heard many times that a 3'' catback is too much for an N/A motor. Everyone suggested a 2.5". So when the opportunity arose I swiched. My exhaust note is considerably more quiet and the intake sound is lessened as well. I have a few pic for you guys to gander at. I'm thinking the mandral bends are a bit extreme. Whatcha think?
Attached Thumbnails Switch from 3" catback to 2.5", performance loss?-leaf-springs-031.jpg   Switch from 3" catback to 2.5", performance loss?-leaf-springs-030.jpg
Old 08-08-2006, 09:05 PM
89macrunner's Avatar
that exhaust is NOT mandrel bent..thats crush bent if the shop told you they do mandrel bends than they lied. sorry to burst the bubble.
Those bends are a little extreme but i doubt youll feel any real performance loss..its probably quieter because of that sharp bend above the axle. If they straighten it out it will be louder and will flow a little better.
Old 08-08-2006, 09:15 PM
Spanky's Avatar
not a fan of those angles
Old 08-08-2006, 10:17 PM
kevin444's Avatar
IMO, i feel 2.5 is still too much for a NA 3.4 motor, i feel 2.25 is the best way to go for optimal tq and flow. If you want something free flowing have that entire tail pipe cut off and have a turn down welded at the outlet of the muffler. Its going to sound like a muscle car.
Old 08-08-2006, 10:50 PM
04 Rocko Taco's Avatar
2.25 inch past the cat, keep a muffler if you want, It'll clean it up, and then go for the 90* turn down. If you just want loud and ragged, do it without the muffler, but I would suggest keeping it in the formula.
Old 08-09-2006, 12:47 PM
Elton's Avatar
i would start over and use 2.25'' pipes all the way back
Old 08-09-2006, 12:50 PM
thats what I meant, use 2.25 inch all the way from the collector past the cat, to the turndown, or to the muffler, and then the turn down, it'll have the big V-8 sounds, just not the loping idle.
Old 08-09-2006, 05:29 PM
MaNiAk's Avatar
sorry for the bad info. I said it was mandral bent not the shop. Now if I do a turn down after the muffler would I have any emmision inspection problems? I live in PHX, AZ.
Blamalam
03-12-2022 07:34 AM
05-20-2016 10:27 AM
justdifferentials
Just Differentials
08-30-2015 08:42 PM
Koolbananass
08-12-2015 01:59 AM
nate2919
08-06-2015 04:00 AM
Quick Reply: Switch from 3" catback to 2.5", performance loss?
