sway bar bushings
Old Oct 5, 2004 | 07:52 PM
Localmotion's Avatar
sway bar bushings
i was wondering what everyone would suggest for new sway bar bushings. Whenever i drive, i hear a sqeek in the front left tire area. Im guessing this is the sway bar bushing? What do you all think, and if i need new ones...which ones should i get? I have a 3rd gen 4x4 btw.
Old Oct 5, 2004 | 08:04 PM
Bigkahuna808's Avatar
I did mine after I did my lift. the lift caused extreme angles in the stock tie rod ends. And cracked the stock sway bar bushing. So I put in the Wheeler's Off Road kit, and the noises dissapeared
Old Oct 6, 2004 | 03:40 AM
Ilovemountains's Avatar
sway bar bushings
Hi, I got my entire kit at Auto Zone made my prothane. I would buy new end links or a set of disco now. My stock end links had to be cut off the bar, there was no removing the sleeve from the bolts! Made a big difference, no more squeeks and bangs/rattles over smaller bumps. The biggest difference to my IFS was when I rebuilt my ball joints and tie rods, idler and pitman arms, now its like a new front end again! Good luck.
Old Oct 6, 2004 | 06:31 AM
HOw much did the kit cost you? I gotta replace my tie rod end also. I got the part from advacned already. Everyone keeps talking about the daystar bushings. Do they make that big of a difference. Im only going 2 inches higher.
Matt
ladybugRC
458
Aug 21, 2020 10:41 AM
live4soccer7
May 11, 2016 06:52 PM
punks_is_4x4
Feb 26, 2016 04:29 PM
Obmi
Oct 4, 2015 11:30 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
