Swap 4th gen Land Cruiser Disc on 3rd gen 4runner - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-23-2005, 11:08 AM   #1 (permalink)
Can you do a rear disc conversion on a 3rd gen 4runner w/ 4th gen land cruiser rear disc brakes? Do land cruisers have the same e-brake setup as 4runners?
-Cyle
cslainson is offline
Old 11-23-2005, 01:45 PM   #2 (permalink)
bdeakin's Avatar
When you speak of the "4th" gen Land Cruiser, of which are you speaking?
Let's see... (And this is rather non-traditional in the LC world)
40 series=1st gen (not really, but it's the first that most are aware of)
50 series=2nd gen (only saw a few of those here... but the few that are here are very cool)
60 series=3rd gen (Hmm..... we'll skip the 70's as I assume you're in the US)
80 series=4th gen (Ok.... I'll assume you're talking about the 80 series)
So... assuming you're talking about the 80 series, there are two models that are native (hah!) to the US. The FJ-80, which was from 91-92 and has drum rears with a semi-floating rear axle, and the FZJ-80 which usually came with a full floating rear and disc brakes in the back.
So... assuming you're talking about getting the disc brakes from a FZJ-80. Then no, I'm not familar with anyone just bringing over the disc brakes. It wouldn't be an easy swap at all. Due to the nature of the 3rd gen's rear axle, I can't think of a way to mash those discs on and have it work.
Now what you could do, is take the entire rear axle (with e-locker of course!) from an FZJ-80 and slap it under your rig. Not easy, but it's been done. As long as you're doing the rear, you'd be doing the front to match your widths which will be skewampus anyway and you've got a solid front to boot (with locker, of course). By this point, you'd have been better off just getting an FJZ-80.
That conversion would be the Hard Way (tm).
I could be wrong though :-)
__________________
BDeakin
'01 Double Cab Tacoma TRD
bdeakin is offline
Old 11-24-2005, 01:15 AM   #3 (permalink)
Thanks for the feedback, just wondering since Ive never heard it mentioned
Old 11-24-2005, 05:56 AM   #4 (permalink)
MTL_4runner's Avatar
Send a message via AIM to MTL_4runner
There has been alot of conversaitons about this but very few people have actually put rear discs on a 3rd gen 4runner. The landcruiser setup will not be adapted very easily but there are definately other options available which would work quite well.
There's quite a bit of reading for you on that topic:
http://yotatech.com/search.php?searchid=1247832
Not on 3rd gens but helps to see the process on most Toyotas:
http://www.4x4wire.com/toyota/reviews/rear_discs/
http://www.mindspring.com/~jayk3/toyota/discs.htm
http://www.birfield.com/%7Emorgan//tech/rdb/
http://4-low.com/tech/rear_elocker/
__________________
- Jamie
1996 4Runner SR5 4X4 Auto
Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift
Best OBD II scan tool I have used!.
.....and I am AMERICAN!
MTL_4runner is offline
Old 11-24-2005, 11:04 AM   #5 (permalink)
ebelen1's Avatar
I've considered this but there are too many variables to worry about (e.g., no e-brake, use Caddy calipers to have e-brake, additional modifications, etc.).
From a $ perspective, I'd recommend upgrading the fronts to the Tundra brake system with steel braided lines (more brake fluid). Keep the drums adjusted properly with the Tundra fronts and you should be fine.
If you do want a 3rd gen rear disc brake conversion, Downey Offroad has a kit for about $500 but you won't have an e-brake. Good luck.
ebelen1 is offline
Tags
3rd, 4runner, 4th, brake, brakes, conversion, cruiser, disc, disk, gen, land, modifications, rear, tacoma, upgrade
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Any 3rd gen 4Runner owners have 4th gen wheels on your truck? LSUMatt1514 95.5-2004 Tacomas & 96-2002 4Runners 8 11-03-2006 04:03 PM
Another 3rd Gen or Land Cruiser? cackalak han General Vehicle Related Topics (Non Year Related) 7 08-24-2006 08:05 PM
Land cruiser FZJ80 springs - Can be used for rear 3rd gen lift ebelen1 The Classifieds GraveYard 24 04-04-2006 07:43 PM
3rd Gen 4runner or Land Cruiser FZJ80? For a DD with 2 under 18 months? X88&94GT 95.5-2004 Tacomas & 96-2002 4Runners 27 03-25-2006 08:57 AM
5VZE 3rd Gen 4Runner / 4th Gen Taco Fan Swap bamachem 95.5-2004 Tacomas & 96-2002 4Runners 3 07-14-2005 04:56 AM
2009 InternetBrands, Inc.
