| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Supra swap questions
__________________
--Brian '94 4Runner SR5 4WD 285 Terra Grapplers on FJ80 wheels|Rancho 9000s on all 4 corners|Cruiser coils|Marlin Rear brake line Stereo CDT Audio CL-61A|CDT Audio CL-6X|Profile 640 and Profile 600M|Audiobahn 100Q |
#2 (permalink) |
i think a better swap for your situation is a 5VZ-FE out of a '96-up 4runner, tacoma, or t100. it'll bolt to your engine mounts and transmission...main issue is wiring.
the supra swap is better for the 4 cylinder guys because it'll bolt up to 20R/22R/22RE engine mounts and a 4 cylinder transmission. main issue there is that the exhaust is on the wrong side and needs to be re-routed. i don't know much about the 2JZ but the 7MGE should run fine on 87 cheapo gas. the 7MGTE is another matter, as it's turbocharged and might ping with lower grade gas. toyota doesn't really differ their tuning between cars that share the same engine, so they should all be about the same
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts past toys: 1984 4x2 1979 4x4 1991 4x4 |
#3 (permalink) |
Put a 1UZ in it. I'm investigating this. I wanted to go diesel, but there are alot of issues with a diesel swap for a DD in PA (inspection issues)
The 2JZ and 7M motors are long and require moving the radiator at a minimum for clearance. I agree with the 5VZE is also a better option.
__________________
UZswap.com A site dedicated to sharing info for swapping the Toyota/ Lexus UZ (V8) engines into Toyota Trucks and 4Runners. My 4Runner 1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys, low lift, hacked fenders, tubbed firewall, custom armor TOOLandFAB.com A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion |
#4 (permalink) |
2jzge can run on 87 and you can get those with tranny very cheap.
__________________
2001 4Runner 3.4V-6 SR5 4x4 | 16x,xxx miles | Stock auto grenaded planetary gear mod | IPT Built A340F stripped Planetary gear mod | Tranny #3 good luck | Stubbs SKO sliders | Bud Built front skid | Trail Carnage belly skid | Rockware rear bumper | Goodyear MT/Rs | | OME 882/890 | Trekmasters | Detroit Locker rear | Truetrac up front | 4.88s 2008 FJC TT SE 6 SPEED |
#5 (permalink) |
The 2JZ engine is in alot of Toy/Lex vehicles:
Supra SC300 GS300 IS300 Probably others too.
__________________
#6 (permalink) | |
Quote:
__________________
84 RN55L-MSEK |
#7 (permalink) |
Hey all.
I've been thinking about a swap recently too. I'm thinking more along the lines of a 7mge (non turbo from factory) and adding a 7mgte exhaust manifold and CT20B turbo. A friend of a friend did this in his Supra and made about 280-300hp and 410 ft pounds of torque. He did have to modify the fuel system and use ARP head bolts and head gasket. Anyhow, that's what I've been thinking about doing recently. From looking around on ebay, the 7mge usually goes for about $350-$550 and the 7mgte usually goes for about $500-750. Transmissions run as cheap as $200. There is a 2004 IS300 engine (similar to the 2JZGE) and auto tranny on ebay right now for $500 I think. Only 5000 miles on it. The VVT-i scares me though, I think wiring would be a pain. I'm also thinking about doing the Lexus 4.0 v8 swap. As cool as a turbo would be, I think the Lexus 4.0 would probably be cheaper in the long run since I wouldn't have to worry about turbo, intercooler, and all that extra stuff. They are great engines and the valve covers look so neat! These engines are dirt cheap on ebay too. Only down side I think is that they take premium gas. Anyhow, that's my $.02. Have fun all. ![]() Daniel
__________________
------------------------------------------------ 1990 4Runner: SR5, 2wd, 3.90 rear, 3VZ-E, auto. 15x8 MT classic II rims, 31x10.50 Bridgestone Desert Duellers ($50!), Cobra CB, 3' firestick Planned stuff: Pre-runner light bar with Hella 500s, small lift Stuff I'd do if I went crazy: SAS, 7mgte or 1UZ swap, and as much offroad goodies as $$ will allow. |
#8 (permalink) |
whatever you decide to do, i HIGHLY recommend getting a complete wrecked car and NOT buy just a motor for several reasons
when you buy just a motor MANY of the important parts are missing like p/s, wiring harness, AFM and other brackets and misc things taking the motor out yourself is a great way to get aquiated with how things go together and you know all the connections have been gently removed (you'd be suprised how brutal a process engine removal is for the places that sell just the motor) you KNOW the car ran before it was in the accident, i bought a motor from a local place and it ended up being from a flooded car and was full of clay (dont even get me started on that waste of $1000) if you have any more specific questions you can pm me, or check out supracharged.com for lots of supra specific info. A supra swap is not HARD, it just takes patience and a little ingenuity with making the I6 fit in there, especially now with the great wiring writeup done by Rob from supracharged.com and if you missed the thread from a few days ago i just posted a vid of my supra motor starting up for the first time, it might just make up your mind for you check out my website
__________________
Jeremy, 94 4Runner Turbo Leaf Spring SAS front - Coilover 4link rear (starts December) / Supra Swap My Truck is featured on Supracharged.com - Home of the original Supra swap and Forum One of two things will happen, I will die, or the truck will be finished. I'm not sure which will be first. Last edited by NCSU-4runner; 01-08-2005 at 09:20 PM. |
#9 (permalink) |
Well my big concern about the 2jz is the wiring from obdI to obdII. With a 7m motor, my car would no longer be legal ( epa requires anymotor put into the car be newer than the car) not a big thing, just saying. Anyone ever swapped from obd1 to obd2?
__________________
#10 (permalink) | ||
you will use the ECU from the new motor so why does the OBD series matter?
and as far as the EPA goes let me copy the PM i just sent to another member on the same topic: Quote:
Theres ALWAYS a way to get around emissions, you just have to try harder.
__________________
Jeremy, 94 4Runner Turbo Leaf Spring SAS front - Coilover 4link rear (starts December) / Supra Swap My Truck is featured on Supracharged.com - Home of the original Supra swap and Forum One of two things will happen, I will die, or the truck will be finished. I'm not sure which will be first. |
| Tags |
| 2jz, ge, odb1, wiring |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 22re Supra AFM Swap questions | Adh007 | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 03-22-2005 10:09 AM |
| OK, I need supra swap help! | the00flaw | 95.5-2004 Tacomas & 96-2002 4Runners | 9 | 11-24-2004 07:50 AM |
| Supra Swap!! | Stump1883 | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 03-08-2004 12:27 PM |
| Help with supra swap | mycotopian | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 08-25-2003 10:28 AM |
| supra swap | 4runner4ever | 95.5-2004 Tacomas & 96-2002 4Runners | 23 | 05-07-2003 02:29 PM |
