Superlift on 94Runner, special tools needed...
Old 03-20-2004, 09:16 AM
victimeiced's Avatar
Me and my father will be putting a 4" Superlift on my 94Runner next weekend. Are there any special tools we are going to need? In the instructions, it says "use a 'puller' to remove ball joint..." Will a hammer work just fine?... or is there a certain tool.
just trying to get everything set for next weekend!
Old 03-21-2004, 11:59 AM
haha c'mon now... i'm sure some of you guys have put on a lift kit before...
Old 03-21-2004, 01:29 PM
Dublin's Avatar
Haven't put a lift in mine yet, but I do know you'll need a puller since the lower ball joints fit by compression. Sure you probably could pound it out but your not gonna get much of a swing, you'll probably damage the treads or bend the shaft, and you'll end up waiting until you get a puller after you've tryed. You might want to look into either renting or buying, they range in price from about $20.00 to $98.00 US.
Old 03-22-2004, 06:08 AM
thanks for the info, i'll look around for it. When i go into a store though, what is it i am asking for? I just say 'i need a puller'?
Old 03-22-2004, 06:40 AM
Away
Dr. Zhivago's Avatar
You can probably borrow a "ball joint puller" from Autozone.
Good luck.
G
Old 03-22-2004, 01:05 PM
blackrunner91's Avatar
hey man, it's about time that someone else on here is using a Superlift kit too. I've had mine on for about 6 months now and I really like it. Anyways, yes, you'll need a "puller" for the ball joints, but if I remember correctly it's only the upper joints that need to be pulled. I used the puller on the tie-rod ends too. It's a fairly easy lift to install, but I did it by myself so there were times that I wanted to set my truck on fire b/c I was so frustrated at it. Get pics of it for us when you're done.
-Louis
Old 03-22-2004, 06:24 PM
awesome thanks for the response... and don't worry i'll have plenty of pics for a before/after thread hehe.
Old 03-22-2004, 06:44 PM
904wdPickup's Avatar
put that kit on my 90 pickup. I didn't use the ball joint puller, just a hammer(but be carfull or you can ruin you ball joint). Also ran into a problem getting the cam bolts out. Had to use the sawzall and cut them. Then replace them with ones i got at the dealer. Also have lots of penatating oil, some of the bolts are a bit rusty.
Old 03-22-2004, 07:09 PM
Del
Del's Avatar
Don't know if you have Kragen back east, but they do free 2 day rentals, and have pretty much any tool you'll need.
Old 03-23-2004, 02:45 PM
awesome... i haven't seen that store around here but i'll def look into it
Old 03-23-2004, 05:40 PM
Away
Kragen, Checker and Schuck's are all the same company.
http://www.partsamerica.com
Chances are, one of them is near you.
G
MichaelKLerner
10-27-2015 07:18 PM
Gravel Maker
RuffStuff
10-04-2015 10:26 AM
Odin
09-24-2015 04:38 AM
mxdw88
09-20-2015 03:13 AM
PureTacoma_Tundra
Vendor Advertising
09-06-2015 06:38 AM
Quick Reply: Superlift on 94Runner, special tools needed...
