Stronger/Beefier Inner Tie Rods?
Old 06-24-2010, 08:31 PM
LINY4Runner's Avatar
So I've just murdered my third set of genuine Toyota inner tie rods, and it got me wondering if there's a set out there built for lifts, oversize tires, and wheeling the piss out of...anyone know?
Old 06-24-2010, 08:41 PM
scottishb's Avatar
What? Where did it break?
Old 06-24-2010, 08:49 PM
Mountain Cop's Avatar
Is it breaking or bending? You could always sleeve them, I suppose.
Old 06-24-2010, 08:54 PM
scottishb's Avatar
I just replaced my inners, outers for like 30 bucks. Off of Ebay. I don't even care if they don't last long.
Old 06-25-2010, 12:12 AM
wyoming9's Avatar
Red face
If you harden them which you can do by heat treating not to be tried at home.
You will then tear up the next weakest part of the system such is life.
Old 06-25-2010, 04:49 AM
well they aren't breaking, but the bushing in the ball & socket joint gets wasted and the wheel has a good 1/2" of play
I want something to eliminate this...
Old 06-25-2010, 07:58 AM
Kerby J's Avatar
cut the ends off and weld on heim joints like i did i almost got stuck one day and messed up my alignment so much that they had to use a come-a-long in order to pull it back into place and had no problems out of the heim joints if u want pics ill post them but that is the best solution
Old 06-25-2010, 11:03 AM
brian2sun's Avatar
I agree, 2 days ago I was just talking to my buddy about converting my LBJs and TREs to heim joints - much stronger.
Old 06-26-2010, 10:30 AM
Spence1016's Avatar
i think i have heard of people using landcruiser tie rods, from fj80s i think...
Old 06-26-2010, 02:20 PM
Ironmike4x4's Avatar
Are you rock crawling or something? I've still yet to change any front end parts on mine and I try to 'wheel at least once a month in it. Granted I'm not crawling over boulders or anything.
Old 06-26-2010, 07:42 PM
dannomite's Avatar
Kerby lets see some pics. I am curious.
Old 06-28-2010, 11:33 AM
scottishb's Avatar
Hey, check out trail-gear.com. I was just looking over there and I ran into some tie rod parts, they looked real tough. You might have to build your own custom setup. Check 'em out, though. And then post pics so everyone can copy off you!
Old 06-28-2010, 11:45 AM
xxxtreme22r's Avatar
was this in addition to the front diff as well? that sucks man. I better go check out mine. lol.
Old 06-28-2010, 04:33 PM
Kerby J's Avatar
dannomite here they are
drivers side
passenger side
Old 06-28-2010, 05:20 PM
cpizzle42's Avatar
I will build you somthing along the lines of this that you will not be able to break....
PM if you are interested
Old 06-29-2010, 07:35 AM
dannomite's Avatar
Both of those look mega beef.
Old 06-29-2010, 02:52 PM
Kerby J's Avatar
havent had a problem yet haha
Old 06-30-2010, 02:36 AM
Kerby those look pretty legit, but the end isn't what's blown on mine...it's the ball and socket joint on the inner
Old 06-30-2010, 06:13 AM
Kerby J's Avatar
LINY4Runner please spesify with a pic if u can or just circle it on one of the ones i posted
Old 06-30-2010, 02:14 PM
I don't have a pic at the moment...it's the joint that's under the boot, that threads directly into the rack
Quick Reply: Stronger/Beefier Inner Tie Rods?
