Stereo Upgrade today!
Finally got all my stuff in the mail that I've had on hold since I went away to fight the war. I know have Kenwood 4"s up front running off the deck along with Kenwood 5 1/4"'s in the cargo area and the factory tweets. Running off the amp I have 2 Kenwood 10"s and two 220W Kenwood 6X9"s It sounds pretty good. I am going to have to get sometthing powered up front the 4"s just arent cutting it anymore. This is the first time I have ever powered anything other than a sub and WOW The 6X9's will about make your ears bleed! The sound is so much clearer than when it comes off the deck. Anyways here are the pics. Can any of you stereo junkies forsee any probs with this set up? There's soo much I could do I know. This system is very very basic.
hey, those pics look familiar
lookin good, ive needed a good way to keep my box on the floor durring serious wheelin and id never thought of doin what you did with the straps across the top to those two anchor points. guess i need to run out and get some straps !
like ive always said
IF ITS TOO LOUD, YOU'RE TOO OLD
The strap works excellent. The metal pieces holding the wedge boxes to the sub box are stainless steel I had laying around. Kinda Ghetto but you can't see it from anywhere anyways. Ideally I wanted my box bolted down for theft reasons but I take it out sometimes when I camp and stuff. All my amp wiring can be disconnected in a matter of minutes. NCSU can you send me another PM with a run down on your system. The way I understood it you have the fronts, 6X9's and subs all powered off your amp. You only have a 4 channel amp right. Anyone know if I could just bridge my fronts in with the 6X9's?
check out the picture of my setup again, theres 2 amps, sorry i didnt make that clear. the red one is a sony 4channel running the 6x9s and whatever is up front in the dash(4in's ?). the black one is a rockford fosgate 2 channel running the subs only.
Gotcha thanks.... disregard the PM I sent you. I eventually want a set up like that with some custom stuff up front like Corey has in his runner.
justdifferentials
Just Differentials
06-13-2022 07:40 PM
