Steering wheel "squalk" on cold mornings
Old 02-11-2004, 05:33 AM
Beachrunner's Avatar
It's been too cold and I haven't had time on the weekends to go tearing into things, but was wondering if anyone else has this annoying sound from their steering column? When I turn the wheel I get a squalking sound which almost sounds like rubber being stretched.
I'm sure it's an easy fix, but wanted to see if anyone has tackled it yet.
Old 02-11-2004, 01:50 PM
zesty
josh's Avatar
You are low on power steering fluid. My 91 used to do it about 1 time a winter.
Old 02-11-2004, 02:07 PM
DSP
DSP's Avatar
Mine does, every once in a while when it is super cold, just for the first minute...
mine sounds like a squeek, or high chirp though.
its been -5 to -10 in the mornings this week...
I haven't checked my power steering, but even when it squeeks for a minute or two when i start er up, i haven't noticed difficulty in turning....
I will check the fluid though when i get home.
Old 02-11-2004, 02:18 PM
zesty
josh's Avatar
It is definately your power steering fluid. I had no difficulty steering when I was having this issue.
Old 02-11-2004, 03:23 PM
So, what if my fluid is full? I think I may spray some WD-40 in there.
Old 02-11-2004, 03:28 PM
zesty
josh's Avatar
Did you check it and it is full, or are you playing what if? If you do decide to lubricate it, don't use WD40. WD40 is for drying electronics...NOT LUBRICATION. You want to use some sort of electronic safe lubricant...I'm sure radio shack has something.
glowz825
01-25-2022 09:28 AM
terminator
07-27-2015 07:13 PM
ty1er
07-19-2015 06:42 PM
redneck17
07-17-2015 07:44 PM
Quick Reply: Steering wheel "squalk" on cold mornings
