Steering rack bushings question.
Old 08-28-2007, 10:26 AM
Question Steering rack bushings question.
I just placed an order for Steering rack bushings for my 1996 4Runner.
Can anyone tell me if I am going to need alignment after installing new Steering rack bushings?
Thanks in advance.
Old 08-28-2007, 10:46 AM
frodin1's Avatar
No. All you mess with is the steering rack itself, not any of the components that have to do with the alignment.
Old 08-28-2007, 11:23 AM
eric-the-red's Avatar
You won't need an alignment but you might find the steering wheel will not be exactly centered after the bushing replacement. I did mine 2-3 months ago and now my steering wheel is very slightly off when the road wheels are straight. I guess when I had the truck aligned last time the old rubber bushings were worn and the rack had shifted slightly. Now with the new poly ones the rack is back where it should be. Not a big deal, but some people find it annoying.
Old 08-28-2007, 11:56 AM
drafn's Avatar
wheres a good place to get the bushings?
Old 08-28-2007, 01:24 PM
Thanks everyone for response.
I am getting it from: http://www.wheelersoffroad.com/4runnerrackbushkit.htm
Old 08-28-2007, 01:39 PM
That's where I got mine too
Old 08-30-2007, 02:10 AM
hopper's Avatar
Thanks in advance.
This might be a stupid question but where did you put the jack stands? B/c you need both wheels off the ground and I only have 1 jack and 2 stands? I tried putting one under the body mount under the door area and didn?t fell comfortable with it there, tried to put it under the front cross member/ brace and still didn?t feel safe with it there.
So where do you put your jack stands when you need both front wheels up at the same time?
Old 08-30-2007, 02:26 AM
Guest
seanz0rz's Avatar
i put it just past where the frame bends to narrow for the front suspension.
heres the only pic i have to give you an idea
glowz825
01-25-2022 09:28 AM
nvdesertrunner
05-11-2020 08:18 PM
choppe777
05-16-2016 08:00 AM
priest16
15
08-06-2015 07:43 AM
HaydenConQueso
07-12-2015 05:22 PM
Quick Reply: Steering rack bushings question.
