YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 04-14-2006, 10:53 AM   #1 (permalink)
northfacer581's Avatar
Send a message via AIM to northfacer581
starter removal help
ok so ive read multiple writeups, and they are helping out a lot. however i am having difficulty locating the 2nd bolt (17mm) that holds the starter in place. the writeup im following is:
http://www.toyotaoffroad.net/afertig...rterrepair.htm
it is helping tremendously, and even he (not sure who did it) said he spent a while staring and trying to find it. im trying to remove my skid plate, but the very front middle bolt that holds it in place is being a PITA; its currently soaking in pb blaster, and hopefully soon it will budge.
i know its pretty much impossible to get a good pic of this...but if anyone has even help as to how to get this second bolt off/moreso actually locating it, it would be greatly appreciated. cuz right now im just sitting here wasting time at a roadblock.
anyone with 3rd gen 4runner starter removal experience, please chime in. thanks.
__________________
-Andy
99 4runner 5speed
Lift: 3" revtek & 2" body; swaybar discos; diff drop
Performance: TRD s/c & 7th injector kit, deckplate closed, elbow removed, TMC 1.1, lock-rite in rear
Protection: tjm15 w/ tabor 9k, custom sliders
Shoes: 305/70/16 nitto terra graps on 16x8 helo maxx 6's
Stuff: lots of lights on the surco, yakima big powderhound right now, shackle hangers, sony head unit, aux fuse box, full time power outlets, seat covers, and home of the herculiner mod
northfacer581 is offline
Sponsored Links
To remove this ad, register today!
Old 04-14-2006, 11:05 AM   #2 (permalink)
o and thanks in advance for links 4crawler's site. got it.
__________________
-Andy
99 4runner 5speed
Old 04-14-2006, 11:09 AM   #3 (permalink)
Cape yota's Avatar
Here's a link to the FSM. Under Engine electrical/Starting system/Starter/Removal and Install there are some pictures that may help. Good luck.
Link
__________________
John
1999 4Runner SR5
Amsoil air filter/extended diff. breather/Revos/Pioneer DEHP-8600MP/Full-time power outlet mod.
NE4ROC member
"All things serve the Beam"
Cape yota is offline
Old 04-14-2006, 11:39 AM   #4 (permalink)
well, i finally figured it out...i guess my starter is different than the ones that i had looked at the writeups for...because i just had 2 14mm bolts holding the starter in place. after staring forever at it, i couldnt find another bolt that was holding it, and there was a 14mm bolt that looked like it held it in place...so i decided to remove it, and it just popped right out.
john preciate the link, that is correct for my starter also. now time to rip into the starter, and replace the contacts. pics to come.
__________________
-Andy
99 4runner 5speed
Old 04-14-2006, 12:58 PM   #5 (permalink)
Sponsoring Member
midiwall's Avatar
Quote:
Link
{hijack}
Where did you find this link? It's an AWESOME reference! There are various pieces of the various FSMs around, but to find a well done JS app like this is way cool. And it has a SEARCH!! THAT WORKS!!!
THANK YOU!
Is epnet a company you work for, or the publisher of the FSMs, or?? I don't think I've ever seen this link before.
{/hijack}
__________________
~ Mark
'96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams
midiwall is offline
Old 04-14-2006, 02:25 PM   #6 (permalink)
well i just finished up.....didnt get any pics because my hands were too nasty and didnt want to mess up the camera.
well bad news....replacing the contacts didnt do anything. and the weird thing about it, is that the old contacts were absolutely destroyed. ?????
now i have suspected one possible mistep i made. i didnt know which contacts i needed, and when i went up to the dealership and got new ones, he gave me 2 different pairs. could i have used the wrong set? they all looked a like to me.
would replacing worn/destroyed starter contacts with new ones that were just slightly different, cause the start to be the exact same, very very weak start as before replacing the destroyed ones?
ive tried to maybe target another area, i just cant get over the fact how worn my old contacts were, and replacing them didnt do anything.
__________________
-Andy
99 4runner 5speed
Old 04-15-2006, 06:55 AM   #7 (permalink)
BennyTRD's Avatar
As long as the plunger came into contact with the new contacts, your starter should work. When I did mine I got some half moon shaped one from the dealer. Did you clean the plunger to make sure that you'd have a good connection when starting??
__________________
'97 4Runner Limited w/E-Locker
'99 Coils w/TrekMasters
265/75/16 BFG AT's
My Profile
BennyTRD is offline
Old 04-15-2006, 09:07 AM   #8 (permalink)
no i didnt, maybe i should do that today. thanks for the heads up.
__________________
-Andy
99 4runner 5speed
Old 04-15-2006, 11:00 AM   #9 (permalink)
hektikwon's Avatar
Yeah clean your plunger with a wire brush and make sure the contacts are in there good and tight. When I did mine the 1st time I neglected this part even though I put in new contacts. I had the same symtoms as before but then I pulled it back about and cleaned the corrosion off of the plunger. I also put a little wd-40 on it to be sure. Works beautiful at every turn of the key!
__________________
91 4x4 4runna 3.4 , auto to manual tranny conversion, 2" body lift, Aisin manual hub conversion, vinyl flooring, 2nd gen inclinometer, 2.5 Magnalow cat & muffler, Trail Gear Sliders, Bilstein Shocks *Gone but not forgotten
96 4runna Limited e-locked and stock
hektikwon is offline
Old 04-15-2006, 01:37 PM   #10 (permalink)
yea i did give it a real good cleaning today, got a lot of junk off.
it starts within 2 seconds of the key being turned, but its just a very weak start; i feel like the gears inside the starter are turning very slowly. but i mean, it hasnt failed me yet, or come close to failing, so maybe im ok?
ill have to test it out in the cold mornings, but right now im charlotte its in the mid 80s.
__________________
-Andy
99 4runner 5speed
Old 04-15-2006, 04:38 PM   #11 (permalink)
MTL_4runner's Avatar
Send a message via AIM to MTL_4runner
Quote:
That one's been around for a little while.
.....it doesn't have everything, but it covers most topics.
__________________
- Jamie
1996 4Runner SR5 4X4 Auto
Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift
Best OBD II scan tool I have used!.
.....and I am AMERICAN!
MTL_4runner is offline
Old 04-15-2006, 08:29 PM   #12 (permalink)
Sponsoring Member
midiwall's Avatar
Wow.. okay.. Must be that od age thing happening again!
__________________
~ Mark
midiwall is offline
Old 04-15-2006, 08:57 PM   #13 (permalink)
ha ^ the old fart cant even spell
__________________
-Andy
99 4runner 5speed
Old 04-17-2006, 06:56 AM   #14 (permalink)
Cape yota's Avatar
{hijack}
THANK YOU!
{/hijack}
Yeah, like MTL mentioned. I saw a link to it on Yotatech awhile ago and bookmarked it. It is a good reference.
__________________
John
1999 4Runner SR5
NE4ROC member
Old 04-17-2006, 07:00 AM   #15 (permalink)
Sponsoring Member
midiwall's Avatar
Quote:
oh gawd! But ya' know, maybe it _is_ the "od" (odd) age thing and not "old" age thing!
__________________
~ Mark
midiwall is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
3rd Gen starter removal 98LimitedCustomized 95.5-2004 Tacomas & 96-2002 4Runners 19 01-14-2007 11:53 AM
Starter removal on '97 LTD BennyTRD 95.5-2004 Tacomas & 96-2002 4Runners 9 10-10-2005 02:06 PM
quick question re: starter removal amorphous 95.5-2004 Tacomas & 96-2002 4Runners 9 09-18-2004 08:19 PM
Starter Removal woes SharkAtaX 95.5-2004 Tacomas & 96-2002 4Runners 7 05-29-2004 11:27 AM
starter removal surfrig 95.5-2004 Tacomas & 96-2002 4Runners 1 01-04-2004 01:01 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
