Is it the starter?
Old Oct 3, 2004 | 03:56 AM
heholaday's Avatar
Question Is it the starter?
The last few weeks, most times I try to start my Runner up it just makes a clicking sound and doesn't even attempt to turn over. I found that when it does this, if I turn the key on, wait a few seconds (after I hear a couple of clicks under the hood) it usually will start right up. Sometimes this process takes several tries. Is my starter going bad?
Old Oct 3, 2004 | 04:03 AM
Cebby's Avatar
Clicking sound is usually an indication of low voltage. Starter problems are "usually" indicated by no noise at all - turn the key and get absolutely nothing. Get a load test done on your battery.
I'm guessing you didn't search since I typed a similar response yesterday for someone else with a similar issue.
Old Oct 3, 2004 | 04:17 AM
heholaday's Avatar
Yeah, actually I did search and most of the posts are talking about the contacts...I'll check the battery load first.
Old Oct 3, 2004 | 07:11 AM
Jonathan's Avatar
Might be an ignition coil, Take it to Autozone and they'll run a battery, alternator and starter test for free, that way you can narrow it down.
Old Oct 3, 2004 | 07:44 AM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
Certainly sounds like a voltage problem. You could luck-out and just have dirty battery cable terminals.
Old Oct 3, 2004 | 08:12 AM
4Crawler's Avatar
I have some troubleshooting ideas on my starter repair page...
ladybugRC
458
Aug 21, 2020 10:41 AM
pickle6415
Oct 19, 2015 08:08 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
bradahman
Oct 1, 2015 09:24 AM
beltcutter
Sep 30, 2015 06:14 AM
